[Qgis-user] Field Calculator behavior
    DelazJ
    delazj at gmail.com
    Wed Mar  1 06:51:11 PST 2017
Did you consider using the quick field calculation bar
http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/attribute_table.html#the-quick-field-calculation-bar
It's supposed to be a kind of shortcut to field calculator dialog.
Harrissou
2017-03-01 14:34 GMT+01:00 Geco Enterprises <gecochile at gmail.com>:
> Similarly for raster calculator
> Sent from my iPhone
> On 1 Mar 2017, at 09:38, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> +1
> Yes! it would be pretty handy
> 2017-03-01 5:52 GMT-05:00 Andreas Wicht <a.wicht at gmail.com>:
>> Hi,
>> the current default behavior of the field calculator is that once it
>> finishes a calculation it closes.
>> Is there a possibility to prevent this from happening and keep it open?
>> That is particularly useful when several columns need to be updated.
>> If there is no such option currently available, would it be feasible
>> to introduce a checkbox "keep open" to the field calculator?
>> Cheers
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170301/59c1120a/attachment.html>
