[Qgis-user] Question on Spatialite
    Nyall Dawson
    nyall.dawson at gmail.com
    Wed Mar  1 14:41:29 PST 2017
On 2 March 2017 at 08:33, Randal Hale <rjhale at northrivergeographic.com> wrote:
> Attribute! Used Field Calculator to split an attribute to get the zipcode
> into a standalone column. I then hit save and watched the fun.
Can you try doing this outside of the attribute table? Ie just click
the main window field calculator toolbar button and see if the
performance is the same?
Nyall
> And yes that seems to be it. Good, I'm not crazy (on this issue).
> Randy
> On 03/01/2017 05:23 PM, Nyall Dawson wrote:
>> On 2 March 2017 at 08:08, Randal Hale <rjhale at northrivergeographic.com>
>> wrote:
>>> I'm using 2.18.4
>>> I'm working with Address point data. My typical process is to import the
>>> data into PostGIS/Postgresql and work with it. I decided to work with
>>> spatialite and do some data cleanup.
>>> I have 222519 points. I made a change to all of them and hit save.
>> What change did you make? Attribute or geometry? How was this change made?
>> It possibly relates to this ongoing work:
>> https://github.com/qgis/QGIS/pull/4175
>> Nyall
>>> So for
>>> the next 20 minutes I watched a very small journal file appear and
>>> disappear
>>> and QGIS just locked up until it was done. QGIS returned to normal and
>>> I'm
>>> working along again.
>>> So my question is - Can I avoid this happening easily or is this just a
>>> "it's what happens with spatialite" problem? Am I missing a setting
>>> somewhere?
>>> Randy
>>> Randal Hale
>>> North River Geographic Systems, Inc
>>> http://www.northrivergeographic.com
>>> 423.653.3611 rjhale at northrivergeographic.com
>>> twitter:rjhale     http://about.me/rjhale
>>> http://www.northrivergeographic.com/introduction-to-quantum-gis
>>> https://www.facebook.com/NRGSInc
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
