[Qgis-user] Interpolation plugin error message
antonio scotti kiaikidobcn at yahoo.com
Fri Mar 10 06:01:25 PST 2017
Hi Lorenzo, I tried to interpolate before cutting the contour lines layer but it takes a massive amount of time to generate and blocks my computer, taking all its computational resources. Apparently this (cropping a layer by a rectangle with the geoprocessing tool and then interpolate) works well on a previous version of QGis I wonder why it doesn't in the latest releases??????
I tried to do this with the latest release of QGIS 2.18.....I have a laptop with win8.1 Intel core I5 and Gb ram....only!
Any other "simple" way that this can be done?Cheers ===============================================
PermaCultura-es http://www.permacultura-es.org
    Il Mercoledì 8 Marzo 2017 14:25, Lorenzo Bambi <lorenzo.bambi at gmail.com> ha scritto:
 2017-03-08 0:23 GMT+01:00 antonio scotti <kiaikidobcn at yahoo.com>:
> Hi all, I am new to this forum and to QGIS
> I am trying to construct a DEM from contour lines by using QGIS 2.14.0.
> I am doing this by using a clip rectangle on top of the contour lines and
> interpolating, by using the interpolation plugin
> After I enter the data in the interpolation dialog and clic Save  I get an
> exception (se attached file).
> Any help appreciated
I have the same problem if i cut vector layers previously with
geoprocessing clip. If you want use the interpolation plugin, try not
to cut the vector layers, but after, cut the dem (raster -->
Exstraction --> Clipper).
Lorenzo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170310/1737bb4c/attachment.html>
