[Qgis-user] How to merge layers without a work-around?
Matthias Kuhn
matthias at opengis.ch
Sun Mar 12 03:51:32 PDT 2017
Hi Tobias,
The native tool was broken in 2.18.4 but is fixed now
http://hub.qgis.org/issues/16292
Please try the latest nightly from 2.18 (and comment on the issue if
it's still not fixed) so this can be shipped in a good shape with 2.15.
Thanks
Matthias
On 3/9/17 9:33 PM, Tobias Wendorff wrote:
> Hi there.
> Is there any way to merge two scratch layers? Even big ones...
> I've tried the one in SAGA, in MMQGIS and the native QGIS one.
> SAGA's executable crashed after 5 minutes, but QGIS was alive.
> MMQGIS also throw out an error after some minutes of processing.
> And the native one tells me:
> "global name 'dataobjects' is not defined See log for more details"
> Actually, this sems to be a bug in "Merge.py":
> "layer = dataobjects.getObjectFromUri(layerSource)"
> I've ended up selection all elements and copy & paste them to a
> new layer. But there's also an unexpected event: even when you've
> selected all the elements in two layers, you can copy the layer,
> which is currently selected in the layers panel. Is this a bug?
> How do you merge layers? Sure, there's ogr2ogr - but I want
> to use QGIS. Of course, I'm merging layers with the same
> geometry only (f.e. points).
> Best regards,
> Tobias
> Qgis-user mailing list
