[Qgis-user] Cartography of the Azores
Alexandre Neto
senhor.neto at gmail.com
Mon Mar 13 15:34:00 PDT 2017
And this:
http://www.ideia.azores.gov.pt/projetos/inspire/Paginas/ServVisualizacao.aspx
Alexandre Neto <senhor.neto at gmail.com> escreveu no dia segunda, 13/03/2017
às 22:30:
> Sarah,
> Maybe this is interesting for you:
> http://sig-sraa.azores.gov.pt/SRAM/site/servicos-wms.asp
> Andrew Harfoot <ajph at geodata.soton.ac.uk> escreveu no dia segunda,
> 13/03/2017 às 20:37:
> Hi Sarah,
> I've used Maperitive (http://maperitive.net/) in similar situations to
> download OpenStreetMap map tiles and store them in a local MBTiles
> database, from where QGIS can load them very quickly!
> Rough steps are:
> 1. Decide on your web mapping
> 2. Set the bounds using UI, or running this command (edit min/max Lat/Lon):
> set-geo-bounds 96.1,19.2,97.7,22.4
> 3. Export to MBTiles (edit min/max zoom and path):
> generate-mbtiles minzoom=5 maxzoom=14 file="C:/Projects/Test/Southampton.mbtiles"
> 4. Load the MBTiles file into QGIS!
> This still requires an internet connection to download the data, but the
> process can be left running overnight etc.
> Cheers,
> Andy
> On 12/03/2017 12:28, Sarah Gregg wrote:
> Hi everyone. I'm working on a project based in the Azores and wondered if
> anyone knew of any reasonably good free topographic base maps I can
> download, strictly for non commercial purposes. At the moment, I'm trying
> to use the OpenLayers plugin, but I have a VERY slow internet connection
> which makes OpenLayers or WMS frustratingly slow to load. Thanks in advance
> for any ideas, Sarah.
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Andy Harfoot
> GeoData Institute
> University of Southampton
> Southampton
> SO17 1BJ
> Tel: +44 (0)23 8059 2719 <+44%2023%208059%202719>
> www.geodata.soton.ac.uk
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170313/591d5d87/attachment.html>
