[Qgis-user] GEO-REFERENCER not working
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Mar 14 10:08:42 PDT 2017
I have had this issue with other Windows software lately (Excel).  Could be a windows bug. Good to know you got it going.
Nicolas
> Le 14 mars 2017 à 11:16, civil142 [via OSGeo.org] <ml-node+s1560n5312270h31 at n6.nabble.com> a écrit :
> Hi Nicolas,
> Since your reply I managed to solve it (with some thought triggers from another respondent). Essentially I had two screens, but had to lose one temporarily. When I again had two screens I swapped them around. The Georeferencer must have been appearing out of the viewable area, even though I had two screens once again connected. I swapped the screens back over today and then opened the georeferencer and there it was.
> Many thanks for your help, thankfully the issue is now resolved, but its seems odd that this wasnt resolved by an uninstall / reinstall etc.
> Many thanks,
> Ian
> From: Nicolas Cadieux [via OSGeo.org] [mailto:ml-node+[hidden email]]
> Sent: 14 March 2017 15:12
> To: Ian kirk-ellis
> Subject: Re: GEO-REFERENCER not working
> Hi,
> I don't have the reste of the post.  What is the georefrencer doing?  Do you have other issues with Python extensions?  Is there a funny caracter (like é) in you user name path?  Did you have two screens before and now, only have one?
> You could repost with all the information adding the windows and qgis versions and the installer used.
> You could also have a look at the bug list to figure it out.
> Nicolas
> Le 14 mars 2017 à 10:22, civil142 [via OSGeo.org] <[hidden email]> a écrit :
> Hi Nicolas,
> I removed all the .qgis2 folders within my login, but not from other users, I would imagine I would have to be logged in as them and as some of them have now left the company this may be difficult. I removed the registry keys.
> I did a full uninstall using the uninstall routine, but also used (after this failing) further uninstall software to get rid of remaining elements.
> Many thanks,
> Ian
> Sent: 14 March 2017 14:08
> To: Ian kirk-ellis
> Hi,
> Did you manually remove all .qgis2 folders for all the users in the computers? If you have have 3 users , you have 3 .qgis2 folders.  Did you destroy the registry keys?
> You talk about a full uninstall, what procedure did you use? You must have something lying around giving you problems.
> Nicolas
> Le 14 mars 2017 à 07:27, civil142 [via OSGeo.org] <[hidden email]> a écrit :
> Hi Nicolas,
> It was working originally and I used it a lot. I have uninstalled QGIS several times and replaced with several subsequent versions but it still remains broken. When I click the geo referencer button, nothing happens.
> I have to use QGIS on a new machine to use the geo reference function. You would think that a full uninstall and a reinstall would fix any such issues, however this persists.
> Kind regards,
> Ian
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312222.html
> To start a new topic under QGIS - User, email [hidden email]
> To unsubscribe from QGIS - User, click here.
> NAML
> http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312256.html
> To unsubscribe from GEO-REFERENCER not working, click here.
> NAML
> Disclaimer
> The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
> This email has been scanned for viruses and malware, and may have been automatically archived by Mimecast Ltd, an innovator in Software as a Service (SaaS) for business. Providing a safer and more useful place for your human generated data. Specializing in; Security, archiving and compliance. To find out more Click Here.
> http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312261.html
> NAML
> http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312269.html
> NAML
> Disclaimer
> http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312270.html
> To start a new topic under QGIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312302.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170314/8d7b67ad/attachment.html>
