[Qgis-user] Last Y coordinate sometimes dropped on pasted geometries
Martin Bain
Martin.Bain at lismore.nsw.gov.au
Wed Mar 15 20:48:55 PDT 2017
Hi group,
I have an intermittent problem, sometimes when I copy and paste a geometry the last Y coordinate of the pasted geometry is lost and replaced by zero.
I have seen it happen with points and polylines. When pasting multiple objects the last Y coordinate of the each geometry is lost. It can happen when pasting within one layer, between layers or into a new scratch layer.
All layers and the project have the same CRS (EPSG:28356).
Once it starts happening QGIS needs a restart.
Has anybody else experienced this? Any ideas of the cause, or a fix other than a restart?
Using 2.18.4 on Win 7 32 bit.
Thanks,
Martin.
This email is intended for the named recipient only. The information it contains may be confidential. If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it. If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170316/7d530862/attachment.html>
