[Qgis-user] Error messages in Processing/Grass on files I am not using?
magerlin MAP at ramboll.dk
Fri Mar 17 11:55:56 PDT 2017
When running a simple Grass procedure like v.clean I have now several times
experienced it stopping with error messages like:
"ERROR 4: Unable to open C:/Users/MAP/Documents/@Sync/ADB/Xiangtan\Future
Infrastructure - identified projects-water OSM.shx or
C:/Users/MAP/Documents/@Sync/ADB/Xiangtan\Future Infrastructure - identified
projects-water OSM.SHX.Try --config SHAPE_RESTORE_SHX true to restore or
create it"
But I have not told processing to do anything with this file and it is not
in my project at all?
Some days ago I used processing on this file but not now? Both Qgis and PC
has been closed and restarted since then.
I suspect it has to do with the temporary files written by processing
C:\Users\USER\AppData\Local\Temp and have tried to delete old files from
here but no luck :-(
Complete error message is here:
Grass_Error_Message.txt
<http://osgeo-org.1560.x6.nabble.com/file/n5312905/Grass_Error_Message.txt>
Regards Morten
Currently using Qgis 2.18.3 (OSGeo4),
Windows 7, 64bit
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-messages-in-Processing-Grass-on-files-I-am-not-using-tp5312905.html
Sent from the QGIS - User mailing list archive at Nabble.com.
