[Qgis-user] How to reproject maps of world grasslands
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Mar 20 01:03:36 PDT 2017
On 20-03-17 08:54, Paulo van Breugel wrote:
> Using the definition on the proj4 page, you can define a custom CRS
> (settings --> custom crs). Just fill in under parameters '+proj=igh'.
> I just tried and it gives a good match
> Note that this grassland layer is based on the terrestrial ecoregional
> map of WWF [1]. If you over overlay that on your grassland layer,
> using for the latter the Interrupted Goode Homolosine CRS, you see
> they will overlap perfectly. You could in fact easily recreate the map
> using the ecoregional map.
> Cheers,
> Paulo
> [1]https://www.worldwildlife.org/publications/terrestrial-ecoregions-of-the-world
> On 20-03-17 07:46, Martin wrote:
>> Many thanks Raymond: that is helpful. Now at least I know what the
>> projection is! As QGIS has so many projections it never occurred to
>> me that there may be one that it didn't include. I will now see if
>> there is some other way - outside QGIS perhaps? - to convert this
>> projection into something more friendly (so to speak).
>> Martin
>> On 19/03/17 21:30, Raymond Nijssen wrote:
>>> Hi Martin,
>>> Sorry, I cannot really help you.
>>> Your data seems to be in the (quite odd for distributing data)
>>> projection:
>>> https://en.wikipedia.org/wiki/Goode_homolosine_projection
>>> And it is not recognized by qgis.
>>> Proj4 seems to know it though:
>>> http://proj4.org/projections/igh.html
>>> And I found this:
>>> http://gis.stackexchange.com/questions/17263/is-it-possible-to-use-the-goode-homolosine-projection-in-qgis
>>> Hope it helps (a bit),
>>> Raymond
>>> On 19-03-17 20:49, Martin wrote:
>>>> Hello folks!
>>>> I would like to plot a simple map of the WWF World Grassland Types
>>>> (the
>>>> shape file is available at
>>>> https://www.worldwildlife.org/publications/world-grassland-types
>>>> It is in an unusual projection. The .prj file is:
>>>> PROJCS["World_Goode_Homolosine_Land",GEOGCS["GCS_WGS_1984",DATUM
>>>> ["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM
>>>> "Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION
>>>> ["Goode_Homolosine"],PARAMETER["False_Easting",0.0],PARAMETER
>>>> ["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER
>>>> ["Option",1.0],UNIT["Meter",1.0]]
>>>> The map does not include the outline countries of the world and
>>>> therefore I would like to add these (perhaps the NaturalEarth 110
>>>> million scale country shape file, which is in WGS84).
>>>> However, I cannot figure out how to align the grassland layer and the
>>>> 110 million NaturalEarth layer. As I understand it, I should use
>>>> Save As
>>>> to reproject the grassland shape file with a new CRS (perhaps
>>>> Mercator).
>>>> With Enable on the fly CRS transformation enabled I should then be
>>>> able
>>>> to put the two shape files together - but I am darned if I can obtain
>>>> anything sensible: I cannot get the two layers to align in any way.
Adding to my previous email: setting the project CRS to Interrupted
Goode Homolosine CRS and then opening this and other maps (with OTF
enabled) works. However, reprojecting the layer using save as (and
setting a new CRS) does not. I tried defining the CRS of the layer and
saved it under different name, setting the CRS to EPGS 4326, but the
resulting layer is completely distorted.
>>>> With grateful thanks for any help, Martin
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170320/ff22ebe9/attachment.html>
