[Qgis-user] Unable to open XTF (INTERLIS 2) file in QGIS
Germán Carrillo carrillo.german at gmail.com
Tue Mar 21 07:50:30 PDT 2017
Thanks a lot Even!
Regards,
Germán
2017-03-17 8:15 GMT-05:00 Even Rouault <even.rouault at spatialys.com>:
> On vendredi 17 mars 2017 07:48:05 CET Germán Carrillo wrote:
> > Hi All,
> > I'm attempting to visualize the data contained in a XTF file in QGIS (OGR
> > provider). I'm using these data [1], specifically the Lake polygon layer,
> > which has 3 features.
> > QGIS displays the geometries but cannot distinguish among features, i.e.,
> > if I select one, all 3 lakes are selected. Moreover, all 3 records in the
> > attribute table have the same attributes. Strangely, printing each
> > feature's id using PyQGIS gives me -1.
> > One could think it's an OGR issue; however, the following OGR command is
> > able to distinguish the 3 features properly, each one with its own id and
> > attributes:
> > $ ogrinfo -ro data/CHBaseEx_WaterNet_V1.xtf
> CHBaseEx_WaterNet_V1.WaterNet_
> > WithModificationObjects.Lake
> > I've confirmed this issue in QGIS v2.14.x, 2.18.x, and 2.99 (built on
> > Monday). In the latter, the attribute table shows only one record,
> although
> > QGIS displays 3 polygons.
> > Is this a known problem? Should I create an issue in QGIS Issue Tracking?
> This is an issue in the OGR Interlis 2 driver that didn't set a feature id
> to the features, so it was left to its -1 default value (you could see it
> on the ogrinfo report)
> Fixed per https://trac.osgeo.org/gdal/ticket/6839
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
   |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
http://twitter.com/GeoTux2
http://about.me/germancarrillo
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170321/eff4e54e/attachment.html>
