[Qgis-user] Retrieve Postgis user from connection string
    Rossin Pietro
    pietro.rossin at arpa.fvg.it
    Tue Mar 21 09:15:50 PDT 2017
Hello
In qgis 2.18 is there some way to automatically get the user name used to load a postgis layer?
I need it to populate a table field qgis side, not postgis side (I know I can do the latest using a trigger).
On Postgis I use
IF NEW.user_inser is NULL or NEW.user_inser = '' then NEW.user_inser = (select current_user);
END IF;
IF NEW.user_modif is NULL or NEW.user_modif = '' then NEW.user_modif = (select current_user);
END IF;
NEW.data_inser = current_timestamp;
NEW.data_modif = current_timestamp;
To trap a user who is inserting a new feature and set both insertion and modification user/data
Then If I want to get a user/data that updates a record, how can I do?
I mean as a user insert a feature or that feature is updated then next time I can't use
And as I load this layer in legend Qgis doesn't change user_modif field.
So I'm searching a way to let Qgis change authomatically user_modif field on edit session
I tried to load a query like
select row_number() over(), current_user::text as user
To get the user of a given connection and it performs well but then How can I insert user value in user_modif field?
Any other better way??
Thanks
Pietro Rossin
AVVISO DI RISERVATEZZA Informazioni riservate possono essere contenute nel messaggio o nei suoi allegati. Se non siete i destinatari indicati nel messaggio, o responsabili per la sua consegna alla persona, o se avete ricevuto il messaggio per errore, siete pregati di non trascriverlo, copiarlo o inviarlo ad alcuno. In tal caso vi invitiamo a cancellare il messaggio ed i suoi allegati. Grazie.
CONFIDENTIALITY NOTICE Confidential information may be contained in this message or in its attachments. If you are not the addressee indicated in this message, or responsible for message delivering to that person, or if you have received this message in error, you may not transcribe, copy or deliver this message to anyone. In that case, you should delete this message and its attachments. Thank you.
