[Qgis-user] QGIS X3D processing
Andreas Plesch
andreasplesch at netscape.net
Sat Mar 25 16:27:01 PDT 2017
I would like to share a project for 3d visualization of Qgis content by
utilizing a not very well known ISO standard, the X3D geospatial component
as openly available in the x3dom implementation (http://x3dom.org). As a
first tangible result of this effort, it becomes possible to generate an
interactive 3d model of a DEM on a web page. Here is an example:
https://rawgit.com/andreasplesch/QGIS-X3D-Processing/master/examples/
output/n35w120nedWGS84_200x200.html
This page is directly generated from a DEM raster layer by running a new
processing model. The project uses exclusively the processing framework and
sofar consists of a number of foundational scripts and models. All code and
more examples are available on github:
https://github.com/andreasplesch/QGIS-X3D-Processing
Use the provided instruction if you feel adventurous
This effort is similar to QGIS2Threejs but is just starting out and will
use quite a different approach.
Any comment, feedback or thought is welcome,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170325/c5e06c1a/attachment.html>
