[Qgis-user] Problem with processing plugin.
Fernando M. Roxo da Motta
petro at roxo.org
Sun Mar 26 07:26:02 PDT 2017
Hi all,
I am using QGis 2.18, it was updated today from 2.18.4 to 2.18.5.
The platform is [Xu|U]buntu 16.04 and it was updated from:
deb http://qgis.org/debian xenial main
My locate is:
$ locale
LANG=pt_BR.UTF-8
LANGUAGE=pt_BR:en
LC_CTYPE="pt_BR.UTF-8"
LC_NUMERIC=pt_BR.UTF-8
LC_TIME=pt_BR.UTF-8
LC_COLLATE="pt_BR.UTF-8"
LC_MONETARY=pt_BR.UTF-8
LC_MESSAGES="pt_BR.UTF-8"
LC_PAPER=pt_BR.UTF-8
LC_NAME=pt_BR.UTF-8
LC_ADDRESS=pt_BR.UTF-8
LC_TELEPHONE=pt_BR.UTF-8
LC_MEASUREMENT=pt_BR.UTF-8
LC_IDENTIFICATION=pt_BR.UTF-8
I tryed the "LC_ALL=C" trick to have all messages in english but the
popup didn't showed up, I need to have my original locale active for
the popup show up at the stat time.
If I click the OK the popup goes away and QGis starts without a
problem. I have tryed to rename the '~/.qgis2' directory to a new
name and nothing changed as the plugin was installed along with the
program in system area.
The message, with translations of some Portuguese, was:
[tr: Impossible to load processing plugin due to an error calling
classFactory() method.]
Impossível carregar complemento processing devido a um erro ao chamar o
método classFactory()
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position
490: ordinal not in range(128) Traceback (most recent call last):
File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 333, in
startPlugin plugins[packageName] = package.classFactory(iface)
File "/usr/share/qgis/python/plugins/processing/__init__.py", line
38, in classFactory return ProcessingPlugin(iface)
File "/usr/share/qgis/python/plugins/processing/ProcessingPlugin.py",
line 58, in __init__ Processing.initialize()
File "/usr/share/qgis/python/plugins/processing/core/Processing.py",
line 148, in initialize Processing.addProvider(c())
line 103, in addProvider % (provider.getDescription(),
traceback.format_exc())) UnicodeDecodeError: 'ascii' codec can't decode
byte 0xc3 in position 490: ordinal not in range(128)
[tr: Python version: 2.7.12 ... QGIS Version : 2.18.5 Las Palmas,
25d9df3]
Versão do Python: 2.7.12 (default, Nov 19 2016, 06:48:10) [GCC 25d9df3]
5.4.0 20160609] Versão do QGIS: 2.18.5 Las Palmas, 25d9df3
[tr: Python Path:]
Caminho do Python:
/home/roxo/.qgis2/python
/home/roxo/.qgis2/python/plugins
/home/roxo/lib/python2.7/site-packages/pysit-0.5b3-py2.7-linux-x86_64.egg
/home/roxo/desenv/python/lib/python
/usr/lib/python2.7
/usr/lib/python2.7/plat-x86_64-linux-gnu
/usr/lib/python2.7/lib-tk
/usr/lib/python2.7/lib-old
/usr/lib/python2.7/lib-dynload
/home/roxo/.local/lib/python2.7/site-packages
/usr/local/lib/python2.7/dist-packages
/usr/lib/python2.7/dist-packages/PILcompat
/usr/lib/python2.7/dist-packages/gst-0.10
/usr/lib/python2.7/dist-packages/gtk-2.0
/usr/lib/pymodules/python2.7
/usr/lib/python2.7/dist-packages/ubuntu-sso-client
/usr/lib/python2.7/dist-packages/wx-3.0-gtk2
/home/roxo/.qgis2//python
Let me know how (and if) can I help on this.
Best regards.
Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org> | Editor?
Except where explicitly stated I speak on my own behalf.| VI !!
( Usuário Linux registrado #39505 ) | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
