[Qgis-user] OSGeo Live with VM doesn't work
Salvatore Oliveto
salvatore.oliveto at terralab.eu
Sun Mar 26 09:07:09 PDT 2017
thank you, it was necessary to enable the virtualization options in the
bios, now it works!
Dott. Geol. Salvatore Oliveto
[image: Follow me] <http://it.linkedin.com/in/salvatoreoliveto/>
G.I.S. e Sistemi Informativi Territoriali
TERRALAB srl - Servizi Avanzati per l'Osservazione della Terra
URL: www.terralab.eu
Linkedin: linkedin.terralab.eu
Facebook: facebook.terralab.eu
Email: salvatore.oliveto at terralab.eu
PEC: terralabsrl at pec.it
Mobile: +39 333.9473545
_____________________________________
Informativa Privacy - Ai sensi del D. Lgs n. 196/2003 (Codice Privacy) si
precisa che le informazioni contenute in questo messaggio sono riservate e
ad uso esclusivo del destinatario. Qualora il messaggio in parola Le fosse
pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non
inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie.
Privacy Information - This message, for the D. Lgs n. 196/2003 (Privacy
Code), may contain confidential and/or privileged information. If you are
not the addressee or authorized to receive this for the addressee, you must
not use, copy, disclose or take any action based on this message or any
information herein. If you have received this message in error, please
advise the sender immediately by reply e-mail and delete this message.
Thank you for your cooperation.
2017-03-26 1:43 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> Hi,
> Please set the VM as 64bit Ubuntu, not 32bit
> Best,
> Angelos
> On 03/25/2017 04:49 PM, Salvatore Oliveto wrote:
>> hi, I use Win 10 64 Bit, with osgeolive 10.0, see the attached file...
>> I can use osgeolive with usb drive, but not with VM
>> tell me if you need other informations
>> thank yoy
>> must
>> 2017-03-25 12:59 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>> Hi,
>>> Can you please provide some more info on this issue?
>>> e.g. system architecture, OSGeo-Live version, virtualization platform
>>> etc.
>>> Cheers,
>>> Angelos
>>> On 03/25/2017 12:10 PM, Salvatore Oliveto wrote:
>>> Hi, I followed the procedure for installing osgeolive with VMhttps://
>>> live.osgeo.org/it/quickstart/virtualization_quickstart.html, but
>>> when I start the VM with osgeolive remains black screen and Linux doesn't
>>> start
>>> thank you
>>> Qgis-user mailing listQgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Angelos Tzotsos, PhD
>>> Charter Member
>>> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
> Charter Member
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170326/98d3b7cc/attachment.html>
