[Qgis-user] Getting lon/lat
g.corral g.corral at topodoc.com
Mon Mar 27 01:03:33 PDT 2017
Sorry...
start point: $x_at(0) and $y_at(0)
end point: $x_at(-1) and $x_at(-1)
But Jack Andersen's idea is more effective.
 Cordialement,
 Guayente CORRAL BROTO
   Hydrogéologue / EurGeol n°1336
 http://www.survey-groupe.fr
Chemin d'Enrobert
32200 Gimont
 - Tél: +33 (0)5 62 65 67 65
 - Mob: +33 (0)6 48 74 43 67
-----Original Message-----
To: phi73 at gmx.de
Cc: QGIS User List <qgis-user at lists.osgeo.org>
Date: Mon, 27 Mar 2017 09:30:20 +0200
Subject: Re: [Qgis-user] Getting lon/lat
Hi phi73,
You can get the Lat long for start and endpoints by using the field
calculator in the attribute table.
create a new field and calculate it with the following:
i.g. field "longXstart"  calculate: x(start_point($geometry))
"latYstart" calculate: y(start_point($geometry))
You can do the same for the endpoint by changing start_point with end_point
Furthermore the output will be in the same projection/coordinates as your
layer, but you can do a transform command on the above command with:
x(transform(start_point( $geometry), 'EPSG:25832', 'EPSG:4326')) where the
first epsg code is the current projection and the second one is the target
projection
I have moved the x to the front of the command because the transform
function only works on coodinate sets and i therefore transform x and y and
then extract x.
_Jack Andersen
On Mon, Mar 27, 2017 at 8:17 AM, <phi73 at gmx.de> wrote:
Hello
i have map based on vector data and in it some street elements.
I would like to pick up a line segment and get the lon/lat for
the start vertex and end vertex.
How could it be done the easiest way in QGIS.
thanks
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170327/1dc64b9d/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170327/1dc64b9d/attachment.jpg>
