[Qgis-user] qgis installation problems
Filipe Dias
filipesdias at gmail.com
Wed Mar 29 08:28:00 PDT 2017
Hi
Bad timing then. I purged ubuntugis unstable and qgis/grass/gdal packages
and added "deb http://qgis.org/debian trusty main". However I am also still
getting an error:
d at fd-XPS:~$ sudo apt-get install qgis python-qgis
[sudo] password for fd:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python-qgis : Depends: python-qgis-common (= 1:2.18.5+20trusty) but it is
not going to be installed
Depends: libqgispython2.18.5 but it is not going to be
installed
Depends: libqgis-analysis2.18.5 but it is not going to be
installed
Depends: libqgis-core2.18.5 but it is not going to be
installed
Depends: libqgis-gui2.18.5 but it is not going to be
installed
Depends: libqgis-networkanalysis2.18.5 but it is not going
to be installed
Depends: libqgis-server2.18.5 but it is not going to be
installed
qgis : Depends: libgdal1h (>= 1.8.0) but it is not installable
Depends: libgeos-c1 (>= 3.4.2) but it is not installable
Depends: libgsl0ldbl (>= 1.9) but it is not installable
Depends: libqgis-analysis2.18.5 but it is not going to be installed
Depends: libqgis-app2.18.5 but it is not going to be installed
Depends: libqgis-core2.18.5 but it is not going to be installed
Depends: libqgis-gui2.18.5 but it is not going to be installed
Depends: libqgis-networkanalysis2.18.5 but it is not going to be
installed
Depends: qgis-providers (= 1:2.18.5+20trusty) but it is not going
to be installed
Recommends: qgis-plugin-grass but it is not going to be installed
Recommends: qgis-provider-grass but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
On Wed, Mar 29, 2017 at 12:49 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
> On top of that, there is a problem in the Ubuntu libtiff recent patch,
> which breaks QGIS.
> https://trac.osgeo.org/osgeo/ticket/1897
> On 03/29/2017 02:33 PM, Randal Hale wrote:
> If I understand correctly there is a new version of GDAL in UbuntuGIS that
> is causing a conflict. They are working to resolve it. For instance - I am
> on 2.18.4 and can't upgrade currently. I would install just from the QGIS
> Repository and wait a bit - then upgrade to UbuntuGIS in a few days.
> Randy
> On 03/29/2017 05:26 AM, Filipe Dias wrote:
> Hi
> I am on Ubuntu 16.04 and trying a fresh installtion of the latest 2.18.x
> version with ubuntugis dependencies. I have both "ubuntugis unstable" and
> http://qgis.org/ubuntugis". However this happens:
> fd at fd-XPS:~$ sudo apt-get install qgis python-qgis
> python-qgis : Depends: libqgis-analysis2.18.5 but it is not going to be
> installed
> installed
> qgis : Depends: gdal-abi-2-1-2 but it is not installable
> installed
> Recommends: qgis-plugin-globe but it is not going to be installed
> installed
> Am I doing something wrong?
> Thanks
> Cheers
> Qgis-user mailing list
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Angelos Tzotsos, PhD
> Charter Member
> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170329/697e8b71/attachment.html>
