[Qgis-user] Processing tools stopped working.
Matthias Kuhn matthias at opengis.ch
Thu Mar 30 09:45:26 PDT 2017
If I knew it would be fixed already and we wouldn't be writing here.
On 03/30/2017 06:44 PM, Tyler Veinot wrote:
> Matthias;
> Ok, how do I fix my system/python?
> Tyler
> On Thu, Mar 30, 2017 at 1:35 PM, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     Hi Tyler,
>     this is an issue with the plugin (on some systems) and not an issue with
>     your dependencies.
>     Do not install PyQt packages with pip on the system where QGIS is
>     installed. This will install imcompatible binary libraries which is
>     never a good idea.
>     Matthias
>     On 03/30/2017 06:12 PM, Tyler Veinot wrote:
>     > I am getting Python errors on QGIS Startup for Processing and QEsg, due
>     > to classFactory() error. The issue started when I installed; pip install
>     > python-Qt5, PyQt4-4.11.4-cp27-cp27m-win32.whl,
>     > PyQtdesignerplugins-1.1-py2.py3-none-any.whl, and
>     > pyqtgraph-0.10.0-py2.py3-none-any.whl trying to fill the dependencies
>     > required for the QField Sync plugin which was failing  because it could
>     > not import name uic.
>     > I tried uninstalling the Python Modules 1 by 1 and checking QGIS but
>     > after they were all uninstalled QGIS still failed. I reinstalled QGIS
>     > with no changes. I then uninstalled QGIS and reinstalled using the
>     > OSGeo4W installer. I still get the classFactory() error for as stated above.
>     > Below is the Python Message Log, any thoughts on how to fix this?
>     > 2017-03-30T12:57:321Traceback (most recent call last):
>     >  File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line 333, in
>     > startPlugin
>     >    plugins[packageName] = package.classFactory(iface)
>     >  File "C:/Users/tveinot/.qgis2/python/plugins\QEsg\__init__.py", line
>     > 34, in classFactory
>     >    from QEsg_00Settings import QEsg
>     >  File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line 607, in _import
>     >    mod = _builtin_import(name, globals, locals, fromlist, level)
>     >  File "C:/Users/tveinot/.qgis2/python/plugins\QEsg\QEsg_00Settings.py",
>     > line 41, in <module>
>     >    from QEsg_05Perfil import *
>     >  File "C:/Users/tveinot/.qgis2/python/plugins\QEsg\QEsg_05Perfil.py",
>     > line 31, in <module>
>     >    import matplotlib.pyplot as plt
>     > ImportError: No module named matplotlib.pyplot
>     > 2017-03-30T12:57:341Traceback (most recent call last):
>     > startPlugin
>     >  File "C:/OSGEO4~1/apps/qgis/./python/plugins\processing\__init__.py",
>     > line 37, in classFactory
>     >    from processing.ProcessingPlugin import ProcessingPlugin
>     >  File
>     > "C:/OSGEO4~1/apps/qgis/./python/plugins\processing\ProcessingPlugin.py",
>     > line 38, in <module>
>     >    from processing.gui.ProcessingToolbox import ProcessingToolbox
>     >  File
>     > "C:/OSGEO4~1/apps/qgis/./python/plugins\processing\gui\ProcessingToolbox.py",
>     >    from qgis.PyQt import uic
>     > ImportError: cannot import name uic
>     > startPlugin
>     > 34, in classFactory
>     >  File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line 308, in
>     > loadPlugin
>     >    __import__(packageName)
>     _import
>     > line 29, in <module>
>     >    from processing.tools.general import *              # NOQA
>     _import
>     >  File
>     > "C:/OSGEO4~1/apps/qgis/./python/plugins\processing\tools\general.py",
>     >    from processing.core.Processing import Processing
>     _import
>     >  File
>     "C:/OSGEO4~1/apps/qgis/./python/plugins\processing\core\Processing.py",
>     > line 42, in <module>
>     >    from processing.script.ScriptUtils import ScriptUtils
>     _import
>     >  File
>     "C:/OSGEO4~1/apps/qgis/./python/plugins\processing\script\ScriptUtils.py",
>     > line 30, in <module>
>     >    from processing.script.ScriptAlgorithm import ScriptAlgorithm
>     _import
>     >  File
>     "C:/OSGEO4~1/apps/qgis/./python/plugins\processing\script\ScriptAlgorithm.py",
>     > line 34, in <module>
>     >    from processing.gui.Help2Html import getHtmlFromHelpFile
>     _import
>     >  File
>     > "C:/OSGEO4~1/apps/qgis/./python/plugins\processing\gui\__init__.py",
>     > line 1, in <module>
>     > _______________________________________________
>     > Qgis-user mailing list
>     > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
