[Qgis-user] EasyCustomLabel
Ian Turton
ijturton at gmail.com
Thu May 4 00:57:07 PDT 2017
I have QGIS 2.18.7 installed on 3.19.0-32-generic Linux (Mint 17/Ubuntu 14)
and CustomEasyLabeling is available here.
Ian
On 3 May 2017 at 14:48, Werner Macho <werner.macho at gmail.com> wrote:
> Hi!
> Hmm - one more idea ..
> Plugin manager -> Check for updates on startup ...
> Probably it is set to "every two weeks" or "every month" on linux ..
> But the Plugin should be there for a longer time ..
> But before you continue to find out what happened..
> I just searched for it on my Windows Computer - and I could not find it
> too..
> So maybe a version of it has been withdrawn.. or something else must
> be happening there right now.. at least in QGIS 2.18.7
> I just gave the latests nightly a try ( QGIS 3.0) and there it is
> available ..
> I'm going to try to find out later in the afternoon where the problem
> lies..
> regards
> Werner
> On Wed, May 3, 2017 at 3:33 PM, Janmaat, Johannus <John.Janmaat at ubc.ca>
> wrote:
> > Hello Werner,
> > Thanks for the reply. I checked the settings. Same repository. I used
> http://whatismyipaddress.com/proxy-check and neither my Windows machine
> nor Linux machine are behind a proxy. Both are using QGIS 2.18.7 (Las
> Palmas).
> > The plugin manager shows 474 plugins total for my Windows machine, and
> 473 for my Linux machine. When I search in the plugins list with 'easy'
> the only one that isn't there on the Linux machine is EasyCustomLabel.
> > Any further suggestions?
> > The Linux system is openSuSE Leap 42.2.
> > John.
> > -----Original Message-----
> > From: Werner Macho [mailto:werner.macho at gmail.com]
> > Sent: May-02-17 10:51 PM
> > To: Janmaat, Johannus <John.Janmaat at ubc.ca>
> > Cc: qgis-user at lists.osgeo.org; Suzan Lapp <slapp at climaterra.ca>
> > Subject: Re: [Qgis-user] EasyCustomLabel
> > Hi!
> > Are the settings in the plugin installer options the same?
> > Are you behind a proxy (where one computer has the proxy settings and
> the other does not)?
> > Is the path to the plugin repository the same?
> > Is the QGIS Version the same?
> > The plugin is there . and since a few days also for QGIS3 .. so you
> should be able to install it..
> > regards
> > Werner
> > On Wed, May 3, 2017 at 3:21 AM, Janmaat, Johannus <John.Janmaat at ubc.ca>
> wrote:
> >> Hello,
> >> I am trying to install the plugin EasyCustomLabel on a Linux install
> >> of QGIS. It does not show up on the plugin manager list. It does
> >> show up on a windows install.
> >> Can someone help me figure out how to install it in Linux?
> >> Thanks,
> >> John.
> >> Dr. John Janmaat
> >> Associate Professor of Economics and RIC Chair in Water Resources and
> >> Ecosystem Sustainability
> >> Economics (unit 8), I.K. Barber School of Arts and Sciences
> >> The University of British Columbia
> >> 3187 University Way, Kelowna, British Columbia, V1V 1V7
> >> (250)807-8021
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170504/43cd50f1/attachment.html>
