[Qgis-user] QGIS crash - SOS
DelazJ
delazj at gmail.com
Sun May 7 07:52:17 PDT 2017
2017-05-07 13:37 GMT+02:00 Velizar Strumberger <
velizar.strumberger at gmail.com>:
> Hi Harrissou,
> thank you very much for the advice that SOLVED the problem. All the
> plugins were installed but turned off. I take this opportunity to ask you
> another question:
Good to hear that works
> A long time ago (QGIS Brighton 2.6.1) I used the RGB Composite and it
> worked OK (I get a colored image from three Landsat bands). Now with QGIS
> 2.12 to 2.18 the RGB composite is a gray image. However when I use the
> plugin Semi Automatic Classification I get a "normal" color image.
> Sorry but I'm not used to manipulate raster data. Can't help on that. I
think I read some discussion about this few weeks ago but can't find the
message. I'm CCing the user so that someone else can answer - do not forget
to always reply to the list (instead of direct reply) to make everybody
aware of the evolution of your needs
Regards,
Harrissou
> Thank you once again.
> Regards
> Strumbi
> On Sat, May 6, 2017 at 10:06 PM, DelazJ <delazj at gmail.com> wrote:
>> Hi Strumbi,
>> Processing, vector, raster as well as web menus are filled by plugins
>> features. It means that you need some plugins activated in the Plugin
>> Manager (in this case, Processing, GdalTools and Metasearch) to have them
>> available or contain particular Core features.
>> By cleaning your PC, you reset your QGIS parameters so these plugins need
>> to be reenabled.
>> Hope that helps,
>> Harrissou
>> Envoyé depuis mon HTC
>> ----- Reply message -----
>> De : "Velizar Strumberger" <velizar.strumberger at gmail.com>
>> Pour : <Qgis-user at lists.osgeo.org>
>> Objet : [Qgis-user] QGIS crash - SOS
>> Date : sam., mai 6, 2017 20:33
>> I am in the middle of a project and my QGIS 2.18.1 crashed when I try to
>> start it. In the task manager I notice several applications qgis.db that
>> were running. I had to hard reset my PC. When I started QGIS once again I
>> noticed that in the Menu Toolbar: Processing and WEB were missing. The
>> Vector and Raster menus were almost empty. For Vector only Open Street Map
>> remained and for Rater the Raster Calculator and Align Raster. I
>> uninstalled QGIS, deleted .qgis2, cleaned my registry (CCleaner) and
>> installed QGIS 2.18.7. The result was the same: no Vector or Raster
>> functions except the mentioned. However I did notice that the Decoration I
>> used before QGIS crash remained active (Scale Bar and Arrow).
>> What am I doing wrong. Please help.
>> Thank you in advance
>> Strumbi
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170507/2bd5abec/attachment.html>
