[Qgis-user] Tiff with jpeg compression
Randal Hale
rjhale at northrivergeographic.com
Mon May 8 07:46:31 PDT 2017
My big fear this weekend was I was doing something wrong. I used your
example and now it's not crashing on me. I had it -co 'TILED=YES' - I
just mistyped in the email. I need to update some notes on my end now to
make sure I do this right from here on out.
Andreas and list - I thank you.
Randy
On 05/08/2017 09:46 AM, Neumann, Andreas wrote:
> Hi Randal,
> A crash is always a bug, in my opinion, even if your file isn't
> optimized.
> Note, that the correct parameter is "tiled=yes" not "tiles=yes". Not
> sure if this helps.
> Fyi - here is one of my examples with gdal_warp:
> gdalwarp -of GTiff -wm 500 --config GDAL_CACHEMAX 500 -multi -wo
> NUM_THREADS=2 -wo OPTIMIZE_SIZE=TRUE -srcnodata "255 255 255"
> -dstnodata '255 255 255' -t_srs 'EPSG:2056' -co 'BIGTIFF=YES' -co
> 'TILED=YES' -co 'COMPRESS=JPEG' -co 'JPEG_QUALITY=85' -co
> 'PHOTOMETRIC=YCBCR' -co 'SPARSE_OK=TRUE' Originaldaten/*.tif
> DOP2011_LV95.tif
> the PHOTOMETRIC=YCBCR is specifically to be used for aerial images or
> satellite images.
> Of course, for good performance, you also need the pyramids:
> gdaladdo -r cubic --config BIGTIFF_OVERVIEW YES --config
> COMPRESS_OVERVIEW JPEG --config JPEG_QUALITY 85 --config
> PHOTOMETRIC_OVERVIEW YCBCR --config INTERLEAVE_OVERVIEW PIXEL
> DOP2016_LV95.tif 2 4 8 16 32 64 128 256
> Hope this helps,
> Andreas
> On 2017-05-08 15:29, Randal Hale wrote:
>> * QGIS: 2.18.7
>> * GDAL 2.1.3
>> I have a tiff file. I decided to jpeg compress it for some help with
>> the size.
>> I did: gdal_translate -co compress=jpeg -co tiles=yes oldfile.tif
>> newfile_jpg.tif
>> When I open the file in QGIS (2.18.7) on linux it crashes immediately.
>> When opened on windows if the file is small it takes about a minute
>> but displays. If I compress a larger tiff (compressed size is 1.1 gb)
>> QGIS on windows crashes.
>> I checked for bugs and there seems to be a jpeg bug out there:
>> https://issues.qgis.org/issues/16049
>> If I do this with compress=deflate, QGIS is happy.
>> Anyway - file a bug report? or I'm doing the compression incorrectly?
>> Randy
>> Randal Hale
>> North River Geographic Systems, Inc
>> http://www.northrivergeographic.com
>> 423.653.3611rjhale at northrivergeographic.com
>> twitter:rjhale
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170508/dcdd595b/attachment.html>
