[Qgis-user] Problems installing Mac version from homebrew
Jesús Lopez
jesusl.temez at gmail.com
Thu May 11 07:42:14 PDT 2017
Thanks for your answer Larry. I try your solution but the behavior was the same with identical message. Will try to reinstall homebrew and see what happens.
Best regards
Jesus
> El 10 may 2017, a las 23:53, Larry Shaffer <larrys at dakotacarto.com> escribió:
> Hi Jesus,
> Please follow the standard means of installing the formula:
> brew install osgeo/osgeo4mac/qgis2
> which will automatically 'tap' the osgeo/homebrew-osgeo4mac tap (code repo of formulae).
> If that does not work, then there is something wrong with your basic install of Homebrew.
> If you feel it is still an issue with the OSGeo4Mac tap, please report the issue here:
> https://github.com/OSGeo/homebrew-osgeo4mac/issues <https://github.com/OSGeo/homebrew-osgeo4mac/issues>
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> Boundless Desktop and QGIS Support/Development
> Boundless Spatial - http://boundlessgeo.com <http://boundlessgeo.com/>
> lshaffer at boundlessgeo.com <mailto:lshaffer at boundlessgeo.com>
> On Tue, May 9, 2017 at 6:03 PM, Jesús Lopez <jesusl.temez at gmail.com <mailto:jesusl.temez at gmail.com>> wrote:
> When I try to install last Mac version from Osgeo brew with brew install https://raw.github.com/osgeo/homebrew-osgeo4mac/master/qgis2.rb <https://raw.github.com/osgeo/homebrew-osgeo4mac/master/qgis2.rb> I get this:
> /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:in `require': cannot load such file -- mach (LoadError)
> from /System/Library/Frameworks/Ruby.framework/Versions/2.0/usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:in `require'
> from /usr/local/Library/Homebrew/extend/pathname.rb:2:in `<top (required)>'
> from /usr/local/Library/Homebrew/global.rb:3:in `<top (required)>'
> from /usr/local/Library/brew.rb:16:in `<main>’
> and nothing happens….
> I get the same outuput with brew install qgis2
> Any idea what am I doing wrong?
> Thanks in advance.
> Jesus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170511/31703983/attachment.html>
