[Qgis-user] Moving selected feature to the top of attribute table does not seem to work in 2.18.7
Hernán De Angelis
dhdeangelis at gmail.com
Thu May 18 01:31:57 PDT 2017
Thank you for your fast response, Luigi.
I understand. I can wait for the next release, no problem. As for the
<someValue> question, I will have a look and come back with whatever I
find, but when I found this I wasn't working on any particular project nor
using composer either.
Cheers
Hernán
On Thu, May 18, 2017 at 10:12 AM, Luigi Pirelli <luipir at gmail.com> wrote:
> fixed during the hackfest on current 2.18 code (you have to wait for
> 2.18.8... or update to the latest 2.18 code not the tagged release
> version)
> https://github.com/qgis/QGIS/pull/4306
> and 3.0
> https://github.com/qgis/QGIS/pull/4444
> btw there are some simple workaround to fix temporarly waiting the patch
> release
> workaround 1) in the attribute table, apply a sort on some column =>
> apply sortOnTop
> workaround 2) in your project xml file you should have a tag as:
> <attributetableconfig ... sortOrder="<someValue>" >
> in your case <someValue> is something different from 0 (Ascending) or
> 1 (Descending)... fix it and sortOnTop will be back :)
> btw, pelase let me knwo what value is in <someValue>, because is not
> clear who's set it to a strange value (probably the composer)
> cheers
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-
> intelligence/mastering-qgis-second-edition
> On 18 May 2017 at 10:03, Hernán De Angelis <dhdeangelis at gmail.com> wrote:
> > Hi
> > Yesterday I compiled from source QGIS 2.18.7 in openSUSE Leap 42.2 Linux.
> > Everything went fine and there were no problems with the compilation.
> > However, when using the new installation I realized that the function
> that
> > allows to move the attribute row of a selected feature to the top of the
> > attribute table does not seem to work. This problem was not present in my
> > previously installed version (2.18.6), nor in another machine I use (QGIS
> > 2.14.2, Windows 7) using the same data. I wonder if any other users are
> > experiencing this in 2.18.7, or there is just something wrong with my
> > particular installation.
> > Regards,
> > Hernán
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170518/0b781d8a/attachment.html>
