[Qgis-user] Population statistics in QGIS
Dietrich Heintz dheintz at gmx.net
Tue May 23 06:31:06 PDT 2017
Hi Parv,
in QGIS you can extend the list of tools with the python plugin.
Go in the Menu Plugins/Manage and install Plugins.
A dialogue opens and you can search the web for available plugins for QGIS.
If you search for "buffer" you should find 4 relevant plugins. Depends
on the repositories you have in your plugins-list.
You can extend this list in the settings menu.
The buffer tools are: Buffer by percentage, Multi Ring buffer,
Multi-distance buffer, Wedge buffer processing algorithm.
If you install MMQGIS Toolbox you will find another tool that creates
buffers.
hope this helps
Dieter
Am 22.05.2017 um 17:51 schrieb Parv Aggarwal:
> Hi QGIS Community,
> I’m Parv, an analytics intern at the Latino Community Credit Union
> here in North Carolina. I’m tasked with finding and using GIS software
> to visualize both US Census data and our membership data at micro
> levels to determine best locations for expansions. As per my
> instructions, this means being able to:
> -Visualize Latino population by smaller units than zip codes.  We have
> worked with Census tracts in the past and that is ideal, but there are
> even smaller areas with population data, like census blocks.  If we
> can see in a map where the higher number of Latinos live and also see
> the streets so that we can imagine potential locations and draw areas
> around them, we could identify optimal locations.
> -If we get a proposal for a location, for example a realtor contacts
> us and says “I have a great place for rent at 1309 Cúcuta Dr,” we
> should be able to enter the address in the software and define an area
> around it, draw that area and know how many Latinos live there. The
> areas could be circles, free shape forms, circles cut by major
> highways or barriers we would think people wouldn’t cross…
> -Of course we should be able to add our own data to the software, like
> those addresses of our current members, and be able to look at, say,
> total balances of members who live in a defined area.
> I have installed QGIS and am currently exploring its capabilities via
> the user guide/training manual. I know I first have to do a join on
> census csv population data and block shapefiles. Assuming I’m able to
> do that, I am trying to find relevant sections that would show me how
> to do this micro level aggregation of population data. I believe in
> ArcGIS this is called “create buffers around a point” but I am not
> sure if this is the relevant way to do it in QGIS or not. I searched
> for buffers in the training manual but I still can’t tell if it means
> the same thing or is relevant for my purposes. I’m also going through
> the vector analysis and processing sections but end up getting lost on
> what’s relevant and what’s not. I would greatly appreciate it if
> someone could guide me on being more effective at looking at the
> relevant features for the above needs, as I am unfortunately new to
> using in-depth GIS softwares like this.
> Sincerely
> Parv
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170523/b9f95751/attachment.html>
