Am 25.05.2017 um 20:16 schrieb Tobias Wendorff: > I know, but the field, where you can select the output clearly shows > "meters". If you are complaining about the "Distance to nearest hub" processing algorithm, you should have written that. It seems there is a bug in the algorithm python script. -- Kai Borgolte, Bonn
