[Qgis-user] vector digitizing question
    DelazJ
    delazj at gmail.com
    Thu Nov  9 07:53:23 PST 2017
Might be a side comment but having read
> On 11/09/2017 03:43 PM, Madry, Scott wrote:
> > [...]. How can I, in QGIS,
> > generate these area and perimeter fields to be added? I know I can
> > manually do the areas using the ‘Measure’ tool, but would prefer an
> automated process.
> > Does Arc just create these automatically? Can QGIS?
QGIS can help you calculate these information automatically, without using
the Measure tool and report its values manually. Use the $area or
$perimeter/$length functions from the field calculator (see doc at
http://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/attribute_table.html#field-calculator).
Matthias answer uses these functions automatically at creation but you can
process the calculation any time, in one-click.
Regards,
Harrissou
> > Thanks so much,
> > Scott
> > Scott Madry, Ph.D.
> > Research Associate Professor of Archaeology The University of North
> > Carolina at Chapel Hill
> > Tel         1-919-448-4493
> > Email:    madrys at email.unc.edu <mailto:madrys at email.unc.edu>
> > https://scottmadry.web.unc.edu
> > Skype:   scott.madry
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> This electronic message, as well as any transmitted files included in the
> electronic message, may contain privileged or confidential information and
> is intended solely for the use of the individual(s) or entity to which it
> is addressed. If you have received this electronic message in error please
> notify the sender immediately and delete the electronic message. Any
> unauthorized copying, disclosure or distribution of the electronic message
> is strictly forbidden. NAV CANADA accepts no liability for any damage
> caused by any virus and/or other malicious code transmitted by this
> electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels destinés à
> l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si
> vous avez reçu ce message électronique par erreur, veuillez en informer
> l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation
> ou distribution du présent message électronique est strictement interdite.
> NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout
> virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171109/2cb3f705/attachment.html>
