[Qgis-user] CONEFOR plugin - path not found
Ricardo Filipe Soares Garcia da
ricardo.garcia.silva at gmail.com
Fri Nov 17 00:40:46 PST 2017
Hi Nic
I'm the author of the CONEFOR plugin. In order to best help you, I need
some additional info:
- Did you make sure to install the conefor cli version - available here:
http://conefor.org/files/usuarios/Conefor_command_line.zip;
- You mention that the path is correct. Can you specify what path exactly
you have set?
- What OS are you on;
- Your QGIS version;
Best regards
On Fri, Nov 17, 2017 at 6:09 AM, Niccolò Marchi <sciurusurbanus at hotmail.it>
wrote:
> Hi all,
> I installed and set the plugin CONEFOR Sensinode but when I try to run an
> alg, the small window saying “This alg cannot be run :( - Set the path”
> appears. The path is correct in the Processing options, so I can’t really
> figure out what the problem could be.
> Is anyone else experiencing this? Any idea/suggestion?
> Thank you in advance,
> Nic
> Qgis-user mailing list
___________________________ ___ __
Ricardo Garcia Silva
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171117/391faaa3/attachment.html>
