[Qgis-user] QGIS Save style
Fuenfer-Koenigstein.Benjamin2 at swm.de
Sun Nov 19 23:43:21 PST 2017
You could use Notpad++ and use find/replace with wildcards, “.matches new line” enabled.
Replace ‘<qgis.*<renderer-v2’ with ‘<qgis>\n<renderer-v2’
and ‘</renderer-v2>.*</qgis>‘ with ‘</renderer-v2>\n</qgis>‘.
With “replace in all opened documents” button it’s done in a few seconds.
(Just replace renderer-v2 with the xml-marker of whatever part of the qml you want to keep.)
Question is what you want to achieve with the modified qml. In fact, the current label style is replaced with “no labeling” by loading qml even if there is no label information in the qml.
Best regards
Benjamin
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Casper Bertelsen
Gesendet: Montag, 20. November 2017 05:55
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] QGIS Save style
Actually wrapping the style-part with <qgis> <\qgis> and removing the rest is enough to QGIS to registrer it as a style file
Mvh. / Best regards
Casper Bertelsen
Mail: casperbj94 at gmail.com<mailto:casperbj94 at gmail.com>
Tlf.: 28 56 06 41
On 19-11-2017 20:44, Lene Fischer wrote:
Thanks for your quick reply...
This gives me a lot of work :-(
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthias Kuhn
Sent: 19. november 2017 20:39
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS Save style
Hi Lene,
that's the way it is. It's been on my wishlist to have more control over what's saved for a while, but didn't happen so far.
You might try to manually edit the qml file and remove some definitions, but not sure it works either.
Regards
Matthias
On 11/19/2017 08:36 PM, Lene Fischer wrote:
Hi
Using QGIS 2.18.14 on Windows
I´m trying to save a categorized style (only style not labels ect) If
I save as default or QML file - the labels ect are saved too.
Any ideas ?
Regards
Lene Fischer
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171120/a3400c66/attachment.html>
