[Qgis-user] Field comments
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Thu Nov 23 01:02:43 PST 2017
Hi Carlos,
See: https://github.com/qgis/QGIS-Enhancement-Proposals/issues/91
for the metadata overhaul, in case that is of interest...
Cheers
Stefan
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthias Kuhn
Sent: torsdag 23. november 2017 08.58
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Field comments
Hi Carlos,
Comments are not saved in the project, they are just retrieved from databases.
E.g. Postgres:
COMMENT ON COLUMN my_table.my_column IS 'Employee ID number';
It's a usability issue with QGIS 2.18 that the column is editable in the layer properties, it should be read only.
Sidenote: That's not something that couldn't be changed in a future version, maybe it could be also discussed with the metadata team if there's something ready for this already.
Regards
Matthias
On 11/22/2017 11:14 PM, Carlos Cerdán wrote:
> Hi list:
> Does anyone know how to make comments permanent in the fields of the
> attribute table? (see image on
> https://www.dropbox.com/s/uef2gs0g3qmp1g0/Fields.png?dl=0 )
> When I open the properties of the layer and go to the "fields" tab, I
> can't make the comments recorded. I tried to put the layer in edit
> mode and enter comments with quotes, but nothing.
> Maybe I'm using this feature the wrong way. Any suggestions?
> Carlos Cerdan
> Qgis-user mailing list
