[Qgis-user] Qgis-user Digest, Vol 141, Issue 28
Balazs Major
mballer at gmail.com
Sat Nov 25 06:33:03 PST 2017
2017. nov. 25. du. 12:43 ezt írta ( <qgis-user-request at lists.osgeo.org>):
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Plugin Lat Lon Tools 0.9.7 Update (C Hamilton)
> 2. Re: ubuntugis: Broken after update to 2.18.14 (Bernd Vogelgesang)
> 3. QGIS SVG: outdated warning (Tobias Wendorff)
> 4. Re: Qgis-user Digest, Vol 141, Issue 27 (Hisham Zantout)
> 5. Re: ubuntugis: Broken after update to 2.18.14 (Angelos Tzotsos)
> 6. Re: QGIS SVG: outdated warning (Matthias Kuhn)
> 7. Re: ubuntugis: Broken after update to 2.18.14 (Martin Landa)
> 8. Re: QGIS SVG: outdated warning (Richard Duivenvoorde)
> 9. Re: QGIS SVG: outdated warning (Matthias Kuhn)
> Message: 1
> Date: Fri, 24 Nov 2017 16:16:39 -0500
> From: C Hamilton <adenaculture at gmail.com>
> To: qgis-developer <qgis-developer at lists.osgeo.org>, qgis-user
> <qgis-user at lists.osgeo.org>, Richard Duivenvoorde <
> richard at duif.net>
> Subject: [Qgis-user] Plugin Lat Lon Tools 0.9.7 Update
> Message-ID:
> <CABPxTTqDbW51BbvxeC1yswsBi_cxnroz+iZVe+a1yEkXBnBMVg at mail.
> gmail.com>
> Content-Type: text/plain; charset="utf-8"
> I just uploaded Lat Lon Tools 0.9.7. By user request, I have added a button
> to the Digitizing Toolbar that creates features on a point vector layer. It
> uses the same coordinate parsing as the "Zoom to Latitude Longitude" tool
> meaning that is parses DMS, decimal, WKT notation. It also accepts MGRS
> coordinates. Once parsed it adds a feature to the selected layer - assuming
> it is in edit mode. During the process a dialog box is displayed for
> editing attributes.
> For those using Lat Lon Tools is this a good work flow? is anything awkward
> with it? Do you have any suggestions?
> Link: http://plugins.qgis.org/plugins/latlontools/
> Thanks,
> Calvin
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-user/
> attachments/20171124/d9050acc/attachment-0001.html>
> Message: 2
> Date: Fri, 24 Nov 2017 23:55:29 +0100
> From: "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] ubuntugis: Broken after update to 2.18.14
> Message-ID: <op.y98cmrd6l2i25i at bernd-pc>
> Content-Type: text/plain; charset=utf-8; format=flowed; delsp=yes
> Am 24.11.2017, 20:11 Uhr, schrieb Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> > Hi,
> > We updated GDAL in UbuntuGIS yesterday so QGIS packages need to rebuild.
> > Cheers,
> > Angelos
> Hi Angelo,
> is there any chance that you could synchronize your efforts a little bit?
> It's really strange that shortly after the new QGIS point release, the
> dependencies get changed.
> If this would happen just once in a while, I wouldn't complain at all. But
> this feels more like coordinated chaos ;)
> Thanx for your work
> Bernd
> > On 11/24/2017 06:14 PM, Bernd Vogelgesang wrote:
> >> Hi,
> >> update broke QGIS. Tested with ubuntugis-nigthly-release and ubuntugis
> >> on Xenial.
> >> Any ideas?
> >> Cheers
> >> Bernd
> >> Reading package lists... Done
> >> Building dependency tree
> >> Reading state information... Done
> >> Some packages could not be installed. This may mean that you have
> >> requested an impossible situation or if you are using the unstable
> >> distribution that some required packages have not yet been created
> >> or been moved out of Incoming.
> >> The following information may help to resolve the situation:
> >> The following packages have unmet dependencies:
> >> python-qgis : Depends: python-qgis-common (=
> >> 1:2.18.14+24xenial-ubuntugis) but
> >> 1:2.18.14+git20171123+10b34b9+24xenial-ubuntugis is to be installed
> >> Depends: libqgis-analysis2.18.14 but it is not going to
> >> be installed
> >> Depends: libqgis-server2.18.14 but it is not going to be
> >> installed
> >> qgis : Depends: gdal-abi-2-2-1 but it is not installable
> >> Depends: libqgis-analysis2.18.14 but it is not going to be
> >> installed
> >> Depends: libqgis-app2.18.14 but it is not going to be installed
> >> Depends: qgis-providers (= 1:2.18.14+24xenial-ubuntugis) but
> >> Depends: qgis-common (= 1:2.18.14+24xenial-ubuntugis) but
> >> Recommends: qgis-plugin-globe but it is not going to be
> >> installed
> >> qgis-plugin-grass : Depends: qgis-plugin-grass-common (=
> >> Depends: qgis-provider-grass (=
> >> be installed
> >> E: Unable to correct problems, you have held broken packages.
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
> Message: 3
> Date: Sat, 25 Nov 2017 09:44:10 +0100
> From: "Tobias Wendorff" <tobias.wendorff at tu-dortmund.de>
> Subject: [Qgis-user] QGIS SVG: outdated warning
> Message-ID:
> <064881f89899f16629d0758b169caa22.squirrel at webmail.tu-dortmund.de>
> Content-Type: text/plain;charset=iso-8859-1
> Hi there!
> I'm on latest QGIS2 (stable). When choosing "SVG export" on map composer,
> you'll get this warning:
> "The SVG export function in QGIS has several problems due to bugs and
> deficiencies in the Qt4 svg code. In particular, there are problems with
> layers not being clipped to the map bounding box.
> If you require a vector-based output file from Qgis it is suggested that
> you try printing to PostScript if the SVG output is not satisfactory."
> QGIS2 uses QT5 and there's no PostScript export support anymore ;)
> Shall I file this as a GUI bug?
> Best regards,
> Tobias
> Message: 4
> Date: Sat, 25 Nov 2017 13:13:31 +0200
> From: Hisham Zantout <hishamzantout at gmail.com>
> Subject: Re: [Qgis-user] Qgis-user Digest, Vol 141, Issue 27
> Message-ID:
> <CAFke+NxfEHhixxdjhk=3uBnzd+PPM3ahzWmOkmsxOzQfbgWTwg at mail.
> gmail.com>
> Dear Sirs,
> Greetings,
> I am looking for a plugin to generate Centerlines from a road polygon.
> attached is the road polygon sample
> appreciate your feedback
> regards
> Hisham
> On Fri, Nov 24, 2017 at 10:00 PM, <qgis-user-request at lists.osgeo.org>
> > Today's Topics:
> > 1. Re: WMS/GeoWebCache image quality in QGIS (Andrew Bell)
> > 2. About Zoom level in Qgis2web (info at otuff.com)
> > 3. ubuntugis: Broken after update to 2.18.14 (Bernd Vogelgesang)
> > 4. Re: ubuntugis: Broken after update to 2.18.14 (Angelos Tzotsos)
> > Message: 1
> > Date: Fri, 24 Nov 2017 02:30:36 -0700 (MST)
> > From: Andrew Bell <andrew at geoascent.com>
> > Subject: Re: [Qgis-user] WMS/GeoWebCache image quality in QGIS
> > Message-ID: <1511515836351-0.post at n6.nabble.com>
> > Content-Type: text/plain; charset=us-ascii
> > Stefan, I set the scale from the status bar in QGIS. I haven't looked
> at
> > the QuickMapServices plugin, but I will if it may help.
> > My base-map is aerial photography, to it would be difficult to use vector
> > instead :)
> > Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> > Message: 2
> > Date: Fri, 24 Nov 2017 14:40:57 +0100
> > From: "info at otuff.com" <info at otuff.com>
> > Subject: [Qgis-user] About Zoom level in Qgis2web
> > Message-ID: <f4d15ab5-4a58-c233-380f-4bbd1118054a at otuff.com>
> > Content-Type: text/plain; charset="utf-8"; Format="flowed"
> > Hi all,
> > Need a little help about Qgis2web, all is fine but,
> > Is there any way to have or set a specific zoom level for a web map ?
> > For example, if i set "zoomControl:true, maxZoom:16, minZoom:8", i'd
> > like to set the zoom level to 10 when the map is load ?
> > Try to play with setZoom fonction but without success !
> > Regards,
> > Olivier
> > L'absence de virus dans ce courrier électronique a été vérifiée par le
> > logiciel antivirus Avast.
> > https://www.avast.com/antivirus
> > attachments/20171124/3356f2bd/attachment-0001.html>
> > Message: 3
> > Date: Fri, 24 Nov 2017 17:14:27 +0100
> > To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> > Subject: [Qgis-user] ubuntugis: Broken after update to 2.18.14
> > Message-ID: <op.y97t2dvel2i25i at bernd-pc>
> > Hi,
> > update broke QGIS. Tested with ubuntugis-nigthly-release and ubuntugis on
> > Xenial.
> > Any ideas?
> > Cheers
> > Bernd
> be
> > installed
> > installed
> > installed
> installed
> be
> > installed
> > Bernd Vogelgesang
> > Siedlerstraße 2
> > Tel: 09133-825374
> > Message: 4
> > Date: Fri, 24 Nov 2017 21:11:37 +0200
> > From: Angelos Tzotsos <gcpp.kalxas at gmail.com>
> > Message-ID: <72c9f322-8c23-f781-d48c-d0228fa75557 at gmail.com>
> > Hi,
> > Cheers,
> > Angelos
> > > Hi,
> > > on Xenial.
> > > Any ideas?
> > > Cheers
> > > Bernd
> > > be installed
> > > be installed
> > > installed
> installed
> > > to be installed
> > Angelos Tzotsos, PhD
> > Charter Member
> > Open Source Geospatial Foundation
> > http://users.ntua.gr/tzotsos
> > Subject: Digest Footer
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > End of Qgis-user Digest, Vol 141, Issue 27
> attachments/20171125/de016727/attachment-0001.html>
> A non-text attachment was scrubbed...
> Type: application/zip
> Desc: not available
> attachments/20171125/de016727/attachment-0001.zip>
> Message: 5
> Date: Sat, 25 Nov 2017 13:14:07 +0200
> Message-ID: <568e774f-b366-9d26-aa32-0198750fd50a at gmail.com>
> Dear Bernd,
> The transition of GDAL has been communicated in the UbuntuGIS mailing
> list since Nov 7:
> https://www.mail-archive.com/ubuntu@lists.osgeo.org/msg01406.html
> Also, the hint that the maintenance team (volunteers) is trying to break
> QGIS packages on purpose is totally unacceptable.
> Angelos
> >> Hi,
> >> Cheers,
> >> Angelos
> > Hi Angelo,
> > But this feels more like coordinated chaos ;)
> > Thanx for your work
> > Bernd
> >>> Hi,
> >>> ubuntugis on Xenial.
> >>> Any ideas?
> >>> Cheers
> >>> Bernd
> >>> to be installed
> >>> be installed
> >>> installed
> >>> installed
> >>> to be installed
> Charter Member
> Message: 6
> Date: Sat, 25 Nov 2017 12:20:08 +0100
> From: Matthias Kuhn <matthias at opengis.ch>
> Subject: Re: [Qgis-user] QGIS SVG: outdated warning
> Message-ID: <a44d816b-cf00-4f60-0c79-e4ebed3cd6c6 at opengis.ch>
> Hi Tobias,
> there is no stable release using Qt5 so far. Can you verify with QGIS 2.99?
> Thanks
> Matthias
> On 11/25/2017 09:44 AM, Tobias Wendorff wrote:
> > Hi there!
> > Best regards,
> > Tobias
> Message: 7
> Date: Sat, 25 Nov 2017 12:29:43 +0100
> From: Martin Landa <landa.martin at gmail.com>
> To: Angelos Tzotsos <gcpp.kalxas at gmail.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Message-ID:
> <CA+Ei1OfuUGPFxYQkVP-eTpE6pE=xntmMN8PXUtsxfgoCk-Ra_w at mail.
> gmail.com>
> Content-Type: text/plain; charset="UTF-8"
> Dear Beard,
> 2017-11-25 12:14 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> instead of attacking volunteers in UbuntuGIS you could help with QGIS
> packaging and improve the ecosystem :-)
> Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> Message: 8
> Date: Sat, 25 Nov 2017 12:31:23 +0100
> From: Richard Duivenvoorde <rdmailings at duif.net>
> Message-ID: <8701b6d5-4bc8-2e2f-802f-17605b8800b9 at duif.net>
> I think Tobias was talking about 2.99. Just tested and msg is indeed
> still there...
> Both (svg and pdf) are working here with a simple colored shape with
> labels with me.
> Regards,
> Richard
> On 25-11-17 12:20, Matthias Kuhn wrote:
> > Hi Tobias,
> 2.99?
> > Thanks
> > Matthias
> >> Hi there!
> composer,
> >> Best regards,
> >> Tobias
> Message: 9
> Date: Sat, 25 Nov 2017 12:42:34 +0100
> Message-ID: <abe5aaf5-1a02-b1e7-ac12-54f6a94dcf5c at opengis.ch>
> Hi Richard,
> In this case I was confused by the term stable in the previous message.
> If this is still there on 2.99, can you check if SVG export also works with
> * Transparency
> * Layer blend modes
> IIRC, these were the tricky things.
> Thanks a lot
> Matthias
> > still there...
> > labels with me.
> > Regards,
> > Richard
> >> Hi Tobias,
> 2.99?
> >> Thanks
> >> Matthias
> >>> Hi there!
> composer,
> with
> that
> >>> Best regards,
> >>> Tobias
> End of Qgis-user Digest, Vol 141, Issue 28
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171125/c9422613/attachment.html>
