[Qgis-user] Check if a selectionChanged signal is connected to any slot?
Matthias Kuhn matthias at opengis.ch
Tue Oct 3 00:12:47 PDT 2017
Hi Marian,
Just tell Qt that it shouldn't create the connection more than once
using Qt::UniqueConnection.
Cheers
Matthias
On 10/2/17 5:30 PM, Tudorache, Marian wrote:
> Hi everyone,
> I have connected the signal selectionChanged so some code, which is
> executed after features are selected.
> myLayer.selectionChanged.connect(self.executeAfterSelection)
> Then I have a method self. executeAfterSelection(self, featuresIds)
> The SIGNAl/SLOT tandem works but now I realized every time when I call
> *myLayer.selectionChanged.connect(self.executeAfterSelection)*  It
> does not overwrite my previous call. It creates a second signa/slot
> tandem. During running the method  executeAfterSelection is excuted
> twice, three times etc.
> How can I check if the SIGNAL selectionChanged is connected to the
> slot executeAfterSelection before I run
> myLayer.selectionChanged.connect(self.executeAfterSelection)?
> I tried this:
> receiversCount =
> QtCore.QObject.receivers(QtCore.SIGNAL(“selectionChanged()”)
> receiversCount =
> QtCore.QObject.receivers(QtCore.SIGNAL(“selectionChanged”)
> receiversCount =
> QtCore.QObject.receivers(QtCore.SIGNAL(“myLayer.selectionChanged()”)
> receiversCount =
> QtCore.QObject.receivers(QtCore.SIGNAL(“myLayer.selectionChanged”)
> Every time I get this error:
> QObject.receivers(SIGNAL()): first argument of unbound method must
> have type ‘QObject’).
> Thanks,
> Marian
> This electronic message, as well as any transmitted files included in
> the electronic message, may contain privileged or confidential
> information and is intended solely for the use of the individual(s) or
> entity to which it is addressed. If you have received this electronic
> message in error please notify the sender immediately and delete the
> electronic message. Any unauthorized copying, disclosure or
> distribution of the electronic message is strictly forbidden. NAV
> CANADA accepts no liability for any damage caused by any virus and/or
> other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels
> destinés à l’usage exclusif des personnes ou des organismes à qui ils
> s’adressent. Si vous avez reçu ce message électronique par erreur,
> veuillez en informer l’expéditeur immédiatement et supprimez le. Toute
> reproduction, divulgation ou distribution du présent message
> électronique est strictement interdite. NAV CANADA n’assume aucune
> responsabilité en cas de dommage causé par tout virus ou autre
> programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171003/f51baa4f/attachment.html>
