[Qgis-user] Windows UNC paths with QGIS
Patrick Dunford
blackwhitekez at gmail.com
Tue Oct 3 10:35:52 PDT 2017
If you are typing the entire path manually you must change all the
slashes into forward slashes.
Make it easy for yourself and cllick the Browse button then type into
the filename box at the bottom of the open file dialog:
\\servername\share
then browse to the file to be opened.
On 04/10/17 05:30, Pekka Sarkola wrote:
> Hi!
> Is it possible using Windows UNC paths
> (https://en.wikipedia.org/wiki/Path_(computing)#Uniform_Naming_Convention
> <https://en.wikipedia.org/wiki/Path_%28computing%29#Uniform_Naming_Convention>)
> in QGIS?
> For me it seems that you can open project files from UNC drives, but
> not data sources. Not for input neither output.
> I tried to found some relevant discussion web pages, but really didn't
> found anything relevant. Maybe this is trivial, please point me to
> right place. Thank you
> Note: mapping network drive to letter is not solution. Asking for a
> friend, not have rights to map network drive to letter (like T:\).
> Only UNC's like \\server\directory
> Rgs,
> Pekka
> Pekka Sarkola
> Gispo Oy
> pekka.sarkola at gispo.fi <mailto:pekka.sarkola at gispo.fi> - GSM +358
> 40 725 2042
> www.gispo.fi <http://www.gispo.fi/>– www.paikkatieto.com
> <http://www.paikkatieto.com/>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171004/69b64a32/attachment.html>
