[Qgis-user] Deployment scenarios of QGIS Server projects?
Axel Schaefer axel.schaefer at wheregroup.com
Thu Oct 5 01:03:44 PDT 2017
Hi.
How do you deploy your QGIS Server projects from your desktop to the
server? Let's collect the possibilities. This should not deal directly
with the installation but the deployment of your projects between two
different machines (QGIS Desktop client-machine and QGIS Server
server-machine).
Background: Out of some talks, I know that there are some possiblities
to get your QGIS qgs-files to the server and to let for example Apache
do some work to facilitate an easy way. People are doing that in
different ways, and I would like to know how. And it seems like all the
ways provide a good mechanism to distinguish between the GIS-expert
doing the work on the QGIS project and the sysadmin.
First way, the easy way:
What I'm presenting right now is Level 1 and follows the way Anita
Graser has described in her blog for Ubuntu:
https://anitagraser.com/2012/03/30/qgis-server-on-ubuntu-step-by-step/
in Chapter "Adding a QGIS project file".
After the installation I have the directory "/usr/lib/cgi-bin" with the
2 files qgis_mapserv.fcgi and wms_metadata.xml. For every new project
(in this example called "bonn") I do the following steps.
1.) Create a directory in /usr/lib/cgi-bin called "bonn":
/usr/lib/cgi-bin/bonn.
2.) Make two symbolic links: First to the "qgis_mapserv.fcgi" file and
second to the "wms_metadata.xml" file.
   $ /usr/lib/cgi-bin/bonn % sudo ln -s ../qgis_mapserv.fcgi
   $ /usr/lib/cgi-bin/bonn % sudo ln -s ../wms_metadata.xml
   $ /usr/lib/cgi-bin/bonn % ls
   qgis_mapserv.fcgi  wms_metadata.xml
3.) I create a third symbolic link to the QGIS-Project-file. But that
resides in my home-directory.
   $ /usr/lib/cgi-bin/bonn % sudo ln -s ~/qgisserver/bonn/bonn.qgs
   $ /usr/lib/cgi-bin/bonn % ls -l
   lrwxrwxrwx 1 root root 40 Sep 27 09:43 bonn.qgs ->
/home/aschaefer/qgisserver/bonn/bonn.qgs
   lrwxrwxrwx 1 root root 20 Sep 27 09:38 qgis_mapserv.fcgi ->
   lrwxrwxrwx 1 root root 19 Sep 27 09:38 wms_metadata.xml ->
../wms_metadata.xml
The interesting part is the last one. I can handle my qgis-files in my
own home directory. All I have to do is to call the admin to a) create
the directory, b) create the two symbolic links to the upper directory
content and c) create the symbolic link to my project in my home. If I
chnage the qgs file, the content of the service has changed.
How do I update the content of the qgs-file? In this case via scp or
some similar technique. I have to copy the file to the server. I do it
in the beginning, call my admin to do his 3 steps and after that I can
update my file.
URL to access the WMS:
http://localhost/cgi-bin/bonn/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
Basic condition: I use a central database for my geodata and don't
hassle with local files.
Advantage: Quick and easy and clearly to arrange. Work of GIS-expert can
be done without work of admin.
Disadvantage: Still communication and work to do. Might be sufficient
for small departments with good communication between GIS guy and admin
guy. The URL goes directly to the qgis_mapserv.fcgi file.
So, how do you do it? Do you use rewrites to hide the unneccessary stuff
from the URL and to make it look nicer? Do you use automatisms?
Best regards
Axel
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 23
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com | www.mapbender.org | www.meldemax.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
