[Qgis-user] Error by changing the CRS
DelazJ
delazj at gmail.com
Fri Oct 6 08:55:06 PDT 2017
Hi Pat
2017-10-06 17:20 GMT+02:00 Pat Hin <phi73 at gmx.de>:
> Hello,
> i have an issue under 2.18.13 which i havent had under 2.18.4
> I have a shapefiel with the CRS in WGS 84 which i would like to
> change to UTM 32N by projection.
> I set the project CRS to EPSG:25832, i set the CRS in the imported layer
> to the same
> but still i have the coordinates in WGS84.
> I have done the same under 2.18.4 some months ago w/o any problems.
I'm afraid you did it wrong now and the previous time.
If you just want to display your map in UTM 32N then changing the project
CRS and activating the On the Fly reprojection might do the trick; no need
to change layer projection.
But if you wanted to have your layer in UTM 32N, note that changing the CRS
value in the layer properties doesn't mean that features will be in that
CRS. The CRS option in layer properties is meant to set the projection of a
layer: a projection that you know is the good one but which QGIS couldn't
find either because there's no prj file with your shapefile or it's a
custom projection.
In your case, your data are already in their good CRS, so to put them in
another CRS, you need to do a reprojection, using some of the Processing
tools
See
http://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/vector_properties.html#coordinate-reference-system
and also
http://docs.qgis.org/2.18/en/docs/training_manual/vector_analysis/reproject_transform.html
Regards,
Harrissou
I have attached some screens.
> thx
> pat
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171006/79eff0d0/attachment.html>
