[Qgis-user] Search overall several layers
C Hamilton adenaculture at gmail.com
Sat Oct 14 18:55:37 PDT 2017
Pat,
There is a plugin called layersearch that never made it into the official
plugin repo. This is the URL.
https://github.com/NationalSecurityAgency/qgis-layersearch-plugin
It will do what you need, but you will need to install it manually.
Download the zip file and extract the contents. Rename the
qgis-layersearch-plugin-master folder to layersearch and drop it into where
the QGIS plugins are installed. Launch QGIS and the go to "Plugins->Manage
and Install Plugins..." Select the Installed tab and enable "Layer Search."
If you need more help let me know.
Calvin
On Sat, Oct 14, 2017 at 1:52 AM, Pat Hin <phi73 at gmx.de> wrote:
> Good morning
> i have several layers in attribute tables over them i would like to run a
> serach for a specific ID. I.e. to find in which of this tables the feature
> with this given ID is saved.
> Is there an easy way to do this by standard tools from QGIS GUI?
> thx
> pat
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171014/a5b9d404/attachment.html>
