[Qgis-user] Filter syntax for date fields
Luigi Pirelli luipir at gmail.com
Fri Oct 20 01:25:16 PDT 2017
This could be related with a similar proble reported in
https://issues.qgis.org/issues/16657 assigned to 3ndis (Denis) that
will work on that (master and 2.18) on November during bugfix period.
The parse is done QDateTime and is hard to match the exact QDateTime
format. If it match, than the value is correctly used, otherwise the
current time is used.
probably we need a more general way to parte datetime shared with
editor delegate and functions.
you can do a workaround adding your custom function that instruct
QDate to parse only Y
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 20 October 2017 at 04:30, Patrick Dunford <blackwhitekez at gmail.com> wrote:
> I have a shapefile table with 300,000 records of polygons that I want
> to filter for display on the map canvas. I want to use the field called
> "date" which is defined as a Qdate in the fields list in the
> shapefile's properties.
> The question is how to put in the filter string in the correct syntax
> to give me for example all the records that are for the calendar year
> of 1984.
> For example
>  year("date") = 1984
> will not work because it doesn't accept the year function from the list
> of functions that are available in other expression editors which allow
> a function list to be used.
> In a previous version of this table I had it was actually quite easy
> because the dates were input as a string and the like operator could be
> used. It seems with a date that is actually defined as a date field
> there is no obvious or easy way to input a range of dates (how do you
> put in a date constant) or use a function that will extract part of a
> date from a date field.
> Qgis-user mailing list
