[Qgis-user] lineaments extraction with QGIS
    HernĂ¡n De Angelis
    dhdeangelis at gmail.com
    Fri Oct 20 01:27:20 PDT 2017
Jean,
As far as I understand there is no specific tool for this in QGIS. You
could try to edge detection with the GRASS module i.zc and see what results
you get, which might require interpretation and manual digitization. More
advanced or automatized processing will fall within the realm of pattern
recognition, and will require the application of algorithms (there are
examples the remote sensing literature for this).
Good luck!
/H.
On Fri, Oct 20, 2017 at 10:08 AM, jean Lukusa <lukusam at gmail.com> wrote:
> hello every one ! would you  give me guidelines  about how to extract
> lineaments  using QGIS through satellites  images.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171020/9ec423f5/attachment.html>
