[Qgis-user] minidump after running script
Luigi Pirelli
luipir at gmail.com
Fri Oct 20 01:30:08 PDT 2017
probably the problem is the facto that you use:
https://qgis.org/api/2.18/classQgsFeature.html#ab0a934a1b173ce5ad8d13363c20ef3c8
without cloning geometry... and then you remove the layer => the
geometry pointer is no more valid.
try to do
geom = QgsGeometry( feature.geometry() )
or better
geom = QgsGeometry( feature.constGeometry() )
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 20 October 2017 at 10:08, Reginald <Reginald.Carlier at ingelmunster.be> wrote:
> Hi,
> I am trying to make a report by using a script.
> The script looks as follows:
> from qgis.PyQt.QtCore import *
> from qgis.PyQt.QtGui import *
> from qgis.PyQt.QtWidgets import *
> import processing
> # selectiepolygoon layer contains one multipolygone
> layer=None
> for lyr in QgsMapLayerRegistry.instance().mapLayers().values():
> if lyr.name() == "selectiepolygoon":
> layer = lyr
> break
> # Get the first feature from the layer
> feature = layer.getFeatures().next()
> # fetch geometry
> geom = feature.geometry()
> # remove selectiepolygoon from legend
> my_id = layer.id()
> QgsMapLayerRegistry.instance().removeMapLayers(my_id)
> layers = iface.legendInterface().layers()
> for layer in layers:
> layerType = layer.type()
> if layerType == QgsMapLayer.VectorLayer:
> for feature in layer.getFeatures():
> if feature.geometry().intersects(geom):
> attr =feature.attributes()
> for att in attr:
> print (att.value)
> When I run this script in my project it terminates with a minidump.
> I suspect that the geom is empty at some point?
> Any idea what is wrong with this script?
> Regards,
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
