[Qgis-user] Rule based style - categorize- label
    Alexandre Neto
    senhor.neto at gmail.com
    Fri Oct 20 03:40:50 PDT 2017
Ah! great hint!
Richard Duivenvoorde <rdmailings at duif.net> escreveu no dia sexta,
20/10/2017 às 11:35:
> tldr; FIRST create a categorized styling, then 'change' it to rules.
> If you do a catagorized styling on the same data, you get indeed only
> the values. There it would maybe nice to show (somewhere) the attribute
> name also on which you categorize?
> I think the rationale was that it would be nice to show some rule info
> in the Label of the style?
> BUT: if you first use categorized styling (with the good labels), then
> go back to your styling dialog and select Rule-based, QGIS will 'morph'
> the categories to styles BUT KEEP THE NICE LABELS \o/
> Regards,
> On 20-10-17 12:25, Lene Fischer wrote:
> > OK - L- Then just hard work…. 72 elements * 3. Hope I´m spelling correct
> > Regards
> > *Lene Fischer*
> > Lektor
> > *Københavns Universitet*
> > Institut for Geovidenskab og Naturforvaltning
> > SKOVSKOLEN
> > Nødebovej 77a
> > 3480 Fredensborg
> > DIR 40115084
> > _lfi at ign.ku.dk_ <mailto:lfi at ign.ku.dk>
> > *From:*Alexandre Neto [mailto:senhor.neto at gmail.com]
> > *Sent:* 20. oktober 2017 12:02
> > *To:* Lene Fischer; qgis-user
> > *Subject:* Re: [Qgis-user] Rule based style - categorize- label
> > Hello Lene,
> > I am not sure you can avoid the manual editing task, unless you run a
> > python script.
> > Alexandre Neto
> > Lene Fischer <lfi at ign.ku.dk <mailto:lfi at ign.ku.dk>> escreveu no dia
> > sexta, 20/10/2017 às 10:53:
> >     Hi,
> >     I´m trying to organize data in groups by making a rule based
> >     styling. In the style I create a rule and then categorize. All fine.
> >     But my problem is the label. Initially the label looks fine when I
> >     click Classify. But when I click OK the rule is viewed in the label
> >     field, and I have to do a typing manually :-O
> >     I´ve made a small video https://www.screencast.com/t/Gwwd8S9l6 to
> >     show the problem.
> >     Any suggestion.
> >     Regards
> >     *Lene Fischer*
> >     Associate Professor
> >     *University of Copenhagen*
> >     Department of Geoscience and Natural Resource Management
> >     Forest and Landscape College
> >     Nødebovej 77a
> >     3480 Fredensborg
> >     Denmark
> >     MOB +45 40115084 <+45%2040%2011%2050%2084>
> <tel:+45%2040%2011%2050%2084>
> >     _______________________________________________
> >     Qgis-user mailing list
> >     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com
> > http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171020/52188eb9/attachment.html>
