[Qgis-user] minidump after running script
Nyall Dawson nyall.dawson at gmail.com
Fri Oct 20 17:11:13 PDT 2017
On 20 October 2017 at 18:30, Luigi Pirelli <luipir at gmail.com> wrote:
> probably the problem is the facto that you use:
> https://qgis.org/api/2.18/classQgsFeature.html#ab0a934a1b173ce5ad8d13363c20ef3c8
> without cloning geometry... and then you remove the layer => the
> geometry pointer is no more valid.
> try to do
> geom = QgsGeometry( feature.geometry() )
> or better
> geom = QgsGeometry( feature.constGeometry() )
Just for future reference - this applies to 2.x only. In 3.0 it's safe
to use the original code and you don't need to make these copies.
Nyall
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> On 20 October 2017 at 10:08, Reginald <Reginald.Carlier at ingelmunster.be> wrote:
>> Hi,
>> I am trying to make a report by using a script.
>> The script looks as follows:
>> from qgis.PyQt.QtCore import *
>> from qgis.PyQt.QtGui import *
>> from qgis.PyQt.QtWidgets import *
>> import processing
>> # selectiepolygoon layer contains one multipolygone
>> layer=None
>> for lyr in QgsMapLayerRegistry.instance().mapLayers().values():
>>     if lyr.name() == "selectiepolygoon":
>>         layer = lyr
>>         break
>> # Get the first feature from the layer
>> feature = layer.getFeatures().next()
>> # fetch geometry
>> geom = feature.geometry()
>> # remove selectiepolygoon from legend
>> my_id = layer.id()
>> QgsMapLayerRegistry.instance().removeMapLayers(my_id)
>> layers = iface.legendInterface().layers()
>> for layer in layers:
>>     layerType = layer.type()
>>     if layerType == QgsMapLayer.VectorLayer:
>>         for feature in layer.getFeatures():
>>             if feature.geometry().intersects(geom):
>>                 attr =feature.attributes()
>>                 for att in attr:
>>                     print (att.value)
>> When I run this script in my project it terminates with a minidump.
>> I suspect that the geom is empty at some point?
>> Any idea what is wrong with this script?
>> Regards,
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
