[Qgis-user] Basic Help
Phil (The Geek) Wyatt
phil at wyatt-family.com
Sat Oct 28 00:42:38 PDT 2017
Here are a few solutions from memory...
· add basemaps from external sources (aerial, street, usgs quad),
o Check out a plugin called Quick Map Services and also once you have that loaded get the contributors pack that adds lots more sources for maps. Also use the search function within the plugin
· calculate/display area of polygons in attribute table
o In the attribute table use the field calculator to add a new columns for ObjArea, and then check out the Geometry expressions $area and area
· add X,Y coordinates of existing points to attribute table
o same as above but check the expressions $x, x $y, y
· search for and add points based on X,Y coordinates
o cant remember this one at the moment but I think there is a plugin that makes this easier
There are also lots of great youtube videos for many QGIS functions
https://www.youtube.com/channel/UCrBM8Ka8HhDAYvQY1VX2P0w/videos
Cheers - Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Louise Duffy
Sent: Saturday, October 28, 2017 4:29 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Basic Help
I don't know if this is the correct format for asking these questions, so please re-direct me as needed.
I am used ArcMap for many years to perform pretty basic stuff, but I am not finding QGIS to be as easy of a transition as I had hoped. I am now self-employed, doing some part time consulting for a few clients and I do not have the budget to buy ESRI products, especially when QGIS has such promise.
In the past, my normal use of GIS was to pretty focused on being able to connect dots from GPS data, digitize features using aerial photography and other basemaps. Producing a variety of maps for projects that included exported tables of that data to show coordinates, lengths, area or other characteristics.
I downloaded QGIS version 2.14.19-Essen. I am not familiar with programming languages, scripts or other behind the scenes stuff. When I have looked at tutorials QGIS has, the screens do not match what I see or the process does not work as expected. I don't know if I am missing something with the install or just need a friendly guide to point the way.
Right now, I specifically need help with four things: add basemaps from external sources (aerial, street, usgs quad), calculate/display area of polygons in attribute table; add X,Y coordinates of existing points to attribute table; search for and add points based on X,Y coordinates.
Thanks!
Louise
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171028/00f60da8/attachment.html>
