[Qgis-user] Issue with coordinates in QGIS 2.10
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Mon Oct 30 13:05:10 PDT 2017
Hello,
I am encountering an issue with QGIS 2.10 which I never had before.
When add an arc to the canvas the saved coordinates do not match those from status bar Coordinate field.
Example:
Step1: Click the first point at -2766147, 5189893. The value is from Coordinate field of the status bar.
Step2: Click right at the second point having coordinates -1342991, 6725875. The value is from Coordinate field of the status bar.
Step3: Click right to draw the line: The line is drawn.
Step4: Save the layer.
Step5: From the console I extract the points.
layer = iface.activeLayer()
feature = layer.getFeatures.next()
print feature.geometry().asPolyline()
The console display:
(-1.52996e+06,6.82968e+06), (636778,6.98782e+06).
These coordinate are totally different from those captured in Coordinate field of the status bar.
How do you explain this?
When I hover the mouse over the first and last point of the arc the Coordinate field of the status bar shows the same number for the step 1 and step 2.
Which coordinates are correct?
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171030/041751bf/attachment.html>
