[Qgis-user] How to outline regions consisting of multiple fields
Jeroen Hovens mail at groenebij.nl
Sun Sep 10 17:04:44 PDT 2017
Hi all,
I am trying to create a map with different visualizations for different
attributes.
The map is a basic municipalities map and has at least two other attributes
that I want to show.
Each municipality (each field/polygon) belongs to a region (attribute A)
and each municipality has a feature of some sort (attribute B).
Now I am trying to create a map that will show the borders of the
municipalities (the basic polygons in simple thin outline), the outer
borders of the region (only a thick outline) and for each municipality a
color representing the value of the 'feature'.
My question is: how do I create only a thick outline of the outer border for
each region on my basic municipality map?
I can give each region a color (style rule > categorize), but I don't know
how to create an outline of the region border. Anything I try with lines
affects every single polygon instead of just the outer border of the region.
Is it possible without creating a new layer with the regions as polygons?
Since I will color each municipality according to 'attribute B', I want just
the outer border for each region to be visible to visually indicate to which
region the municipality belongs.
Any idea's?
Regards,
Jeroen Hovens
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170911/fac63d71/attachment.html>
