[Qgis-user] QGIS 2.18 Point labeling with connecting line
Frederick Löbig qgis at linie11.org
Thu Sep 21 00:22:16 PDT 2017
Thank you, Phil!
I had a look at this plugin a while ago, didn't get far with it but, on the other hand, I didn't look to deep into it. I will see what I can achieve and keep you updated on the progress.
Thanks again
Cheers
Freddy
Von: Phil (The Geek) Wyatt <phil at wyatt-family.com>
Gesendet: Donnerstag, 21. September 2017 03:13
An: 'Frederick Löbig'; qgis-user at lists.osgeo.org
Betreff: RE: [Qgis-user] QGIS 2.18 Point labeling with connecting line
I have certainly done something similar using the easy labelling plug in. It really depends on how much you want to control the line lengths etc. Not all points will have the diagonal line (unless you move the label independently)
[cid:image001.png at 01D332CA.9D43B880]
Cheers - Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Frederick Löbig
Sent: Wednesday, September 20, 2017 8:55 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] QGIS 2.18 Point labeling with connecting line
Hi all,
happy to be back here on this mailing list after being away for quite a while.
A lot has changed in QGIS since I last used it, and I am happy to see that QGIS' community still is growing and the software has improved hugely.
Thank you all very much for keeping the community active!
Let's get to the question:
I am currently creating a new map, containing loads of points that need to be labled. No problem so far, but I want to achieve a very specific labeling style, as shown in the following picture:
[cid:image002.png at 01D332CA.9D43B880]
The only thing I have yet to do, is the connecting line between Point and label. Field based labelling, of course, is no problem. I have read about a couple of plugins, but none of them got me there. Any ideads - the horizontal separator between the two lines is actually not really neccesary, but nice to have. Main thing is the diagonal line connecting the feature with the label.
Thanks in advance!
Cheers
Freddy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170921/1956c819/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170921/1956c819/attachment.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170921/1956c819/attachment-0001.png>
