[Qgis-user] How to disable postgresql in the build of QGIS2.99
Patrick Dunford
blackwhitekez at gmail.com
Thu Sep 21 02:08:03 PDT 2017
It is only giving you libraries, isn't it? On Linux systems all you have
to do is install a postgresql developer package. You do not actually
have to set up the Postgresql DBMS or have one available. So all you are
doing building it on Debian (as I have) is having the libraries
available for it to compile.
On 21/09/17 21:02, David Liontooth wrote:
> Thanks, Patrick! I also run a Debian server and checked dependencies
> there; QGIS2 does not require postgresql.
> On my mac laptop, I'd rather not install postgresql -- it's not that
> it's complicated to do so, I just don't expect to use it and would
> rather avoid the clutter.
> So I'm just looking for a way to turn off postgresql in the build of
> QGIS2.99. I tried adding this to David Marteau's makefile:
> -DWITH_POSTGRESQL=FALSE \
> But it's not turning off postgresql. testqgspostgresprovider.cpp
> insists on including it. Maybe I can turn off the test suite?
> So what I'm trying to find out is just how to turn off this
> dependency, since it appears to be optional. Who would know?
> Cheers,
> David
> Configuration from makefile (added libzip lines)
> configure:
> mkdir -p $(BUILDDIR)
> rm -rf $(BUILDDIR)/CMakeCache.txt
> cd $(BUILDDIR) && cmake $(CMAKE_OPTS) \
> -DWITH_ASTYLE=ON \
> -DCMAKE_INSTALL_PREFIX:PATH=$(INSTALL_PATH) \
> -DWITH_SERVER=ON \
> -DLIBZIP_INCLUDE_DIR:PATH=/opt/local/include \
> -DLIBZIP_CONF_INCLUDE_DIR:FILEPATH=/opt/local/lib/libzip/include \
> -DLIBZIP_LIBRARY:FILEPATH=/opt/local/lib/libzip.dylib \
> -DEXPAT_INCLUDE_DIR:PATH=/opt/local/include \
> -DEXPAT_LIBRARY:FILEPATH=/opt/local/lib/libexpat.dylib \
> -DSQLITE3_INCLUDE_DIR:PATH=/opt/local/include \
> -DSQLITE3_LIBRARY:FILEPATH=/opt/local/lib/libsqlite3.dylib \
> -DQT_QMAKE_EXECUTABLE:FILEPATH=/opt/local/libexec/qt5/bin/qmake \
> -DQWT_INCLUDE_DIR:PATH=/opt/local/libexec/qt5/include/qwt \
> -DQWT_LIBRARY:FILEPATH=/opt/local/libexec/qt5/lib/libqwt.dylib \
> -DQCA_INCLUDE_DIR:PATH=/opt/local/libexec/qt5/include/QtCrypto \
> -DQCA_LIBRARY:FILEPATH=/opt/local/libexec/qt5/lib/libqca-qt5.dylib \
> -DQSCINTILLA_INCLUDE_DIR:PATH=/opt/local/libexec/qt5/include \
> -DQSCINTILLA_LIBRARY:FILEPATH=/opt/local/libexec/qt5/lib/libqscintilla2_qt5.dylib
> -DQTKEYCHAIN_INCLUDE_DIR:PATH=/usr/local/include/qt5keychain \
> -DQTKEYCHAIN_LIBRARY:FILEPATH=/usr/local/lib/libqt5keychain.dylib \
> -DQT_LRELEASE_EXECUTABLE:FILEPATH=/opt/local/libexec/qt5/bin/lrelease \
> On 9/20/17 10:24 PM, Patrick Dunford wrote:
>> Ok so I gave you a Linux answer :)
>> The install file I have says you do a postgresql installation through
>> this site, I assume that is supposed to provide the libraries you need
>> www.kyngchaos.com/software/postgres
>> I would guess from that you should be able to work out if it has
>> provided the library file as part of that.
>> On 21/09/17 13:58, David Liontooth wrote:
>>> Great, thanks!
>>> Does QGIS3 require postgresql?
>>> I didn't think it did, but the build bugs out:
>>> In file included from
>>> /Users/liontooth/software/QGIS/QGIS-2.99a/tests/src/providers/testqgspostgresprovider.cpp:4:
>>> /Users/liontooth/software/QGIS/QGIS-2.99a/src/providers/postgres/qgspostgresprovider.h:24:
>>> /Users/liontooth/software/QGIS/QGIS-2.99a/src/providers/postgres/qgspostgresconn.h:33:10:
>>> fatal error: 'libpq-fe.h' file not found
>>> #include <libpq-fe.h>
>>> 1 error generated.
>>> /tests/src/providers/testqgspostgresprovider.cpp seems to demand it.
>>> Cheers,
>>> Dave
>>> On 9/20/17 11:01 AM, Patrick Dunford wrote:
>>>> 3.0 is not released yet, you can only get 2.99 development versions.
>>>> You get them from Github:
>>>> https://github.com/qgis/QGIS
>>>> Click on "Clone or Download" button on the right and then "Download
>>>> Zip"
>>>> This is for the latest release, you can get older ones if you know
>>>> the commit ID
>>>> On 21/09/17 05:51, David Liontooth wrote:
>>>>> I followed David Marteau's very helpful instructions for building
>>>>> QGIS3 at
>>>>> https://www.3liz.com/blog/rldhont/index.php?post/2017/06/01/How-to-build-qgis-on-OSX-with-MacPort,
>>>>> on a Sierra OS X with all updates and a current MacPorts
>>>>> installation.
>>>>> I needed to add these dependencies:
>>>>> lbzip2 py36-setuptools
>>>>> Where can I find QGIS 3.0 source files? I downloaded
>>>>> http://qgis.org/downloads/qgis-latest.tar.bz2, but that's
>>>>> qgis-2.18.13.
>>>>> I also tried https://github.com/wonder-sk/QGIS/archive/3d-2.zip,
>>>>> using Marteau's makefile, replacing spaces with tabs. Cmake didn't
>>>>> find libzip, so I modified
>>>>> cmake/FindLibZip.cmake txt2tags
>>>>> to include the paths to MacPort's libzip package (/opt/local/..).
>>>>> However, there's a syntax error relating to the 3D features,
>>>>> reported separately.
>>>>> Is there a mainline version of QGIS3 we can test build, just to
>>>>> get ready for the release?
>>>>> Cheers,
>>>>> Dave
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170921/28de8a9c/attachment.html>
