[Qgis-user] Installing QGIS lastest release in UBUNTU 14.04
Patrick Dunford blackwhitekez at gmail.com
Thu Sep 21 09:20:30 PDT 2017
On 20/09/17 02:57, Andre Joost wrote:
> Semms you got stuck with the gdal-abi package. You can try the
> solution given at
> https://gis.stackexchange.com/questions/218528/qgis-depends-on-gdal-abi-2-1-1-not-installable
> You may try the ubuntugis unstable ppa, instead of the ubuntugis
> (stable) ppa.
> I suggest to install in a terminal, not with the Ubuntu software
> center. You need to update your packages list first, then install the
> dependent GDAL packages.
> BTW why "trusty partner"?
I don't think there is a partner branch of the ubuntugis repository, it
should be set as main
