[Qgis-user] GRASS support lost (again) on Ubuntu/Mint
Patrick Dunford blackwhitekez at gmail.com
Wed Sep 27 02:19:44 PDT 2017
There is also a problem with a missing key for the ubuntugis
repositories (089EBE08314DF160). There are no instructions provided on
where the key can be obtained.
On 27/09/17 19:30, Andre Joost wrote:
> Am 26.09.2017 um 21:04 schrieb Patrick Dunford:
>> If you can actually state where abouts in the Ubuntugis repository the
>> actual packages that will make 2.18.13 work on Ubuntu 16.04 are because
>> they are not in the regular Ubuntugis repository.
> GRASS 7.2.1 for xenial is now in the Ubuntugis (stable) PPA:
> https://launchpad.net/~ubuntugis/+archive/ubuntu/ppa/
> Unfortunately, you need libgdal-grass as well, but this is built on
> GDAL 2.1.3, but QGIS is built on GDAL 2.2.1.
> If you force the older GDAL, QGIS will get removed, so the situation
> is dead-locked for now.
> You may wait to let the devs fix it, or switch to the QGIS debian repo
> (returning to GDAL 1.11.3).
> HTH,
> André Joost
> Qgis-user mailing list
