[Qgis-user] How do I update attribute values in a composer attribute table?
David Gessel
gessel at blackrosetech.com
Wed Sep 27 05:08:13 PDT 2017
I have a configured an attribute table in a print composer, it pulls values from an imported (GE) KML layer, "name" and "description" (and lat/lon). These display nicely. But I updated the values in GE and these updates are not reflected in the attribute table. I've pressed the "refresh table data" button and the "refresh view" button (many times) and even restarted to no avail.
Looking at the values for the field values in Print Composer->Attributes->Expression Dialog window, I get an old, not refreshed list.
While looking at the same data via the label tool in map mode Map->Layer->Properties->Label With->Expression Dialog (not composer mode), I see the correct, current values.
I'd think the table data should update both in map mode and in composer mode, but barring that, is there a way to update the attribute table in composer? Do I need to delete all tables and recreate them every time the underlying field values change to get them to update?
I also posted this question to https://gis.stackexchange.com/questions/256761/how-do-i-update-attribute-values-in-a-composer-attribute-table
with screen shots.
Thanks,
David
