[Qgis-user] Working with geopackages in Qgis
    Stéphane Henriod
    s at henriod.info
    Wed Sep 27 23:45:04 PDT 2017
Hi Andreas
Thanks for your comments!
Here the Gdoc with my first ideas:
https://docs.google.com/document/d/1xp36eR0DYThpTCNsWUam5JhFKVjOVpmRObwWSPjkrbc/edit?usp=sharing
Cheers
Stéphane
Stéphane Henriod
CIM-Expert for GIS and Green Economy Statistics
Национальный статистический комитет Кыргызской Республики
Кыргыз Республикасынын Улуттук статистика комитети
National Statistical Committee of the Kyrgyz Republic
374 Фрунзе ул. / Frunze str.
720033 Бишкек / Bishkek
T   +996 778 46 99 02 (KG)
T   +49 176 280 11 050 (DE)
E    s at henriod.info
W   http://www.stat.kg
W3W: nightfall.into.bucket
<https://map.what3words.com/nightfall.into.bucket>  //  запас.союз.дружный
<https://map.what3words.com/запас.союз.дружный>
2017-09-28 12:23 GMT+06:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Stéphane,
> Thanks for your ideas. It is my personal goal (and the goal of the Swiss
> QGIS user group) to make Geopackage the number 1 file-based format in QGIS
> and put Shapefiles in the graveyard.
> Therefore we paid Even Rouault in the past for some geopackage
> improvements. Swiss provinces also invested into a tool name ili2gpkg - a
> tool that can read official swiss data models in Interlis format and
> generate the data structure in a geopackage - incl. import of data, if it
> already exists. This is in parallel with a similar tool called ili2pg that
> does the same for Postgis.
> As you discovered there are more issues around Geopackages to make them as
> hassle-free as possible. I also think the raster part of geopackages did
> not get too much attention so far.
> Since you have been so successful with your campaign around improving
> discrete/paletted rasters - may I suggest the same for Geopackage
> improvements? You can start a list of useful improvements in a Google Docs
> document or on Github as a QEP. Other people can contribute and we can find
> a way to fund the improvements. Both QGIS-CH and QGIS.ORG could help with
> the financing aspect.
> Some feedback to your 3 issues:
> ad 1): you are right - it is not possible to easily create an empty
> geopackage. One always starts with a vector layer.
> ad 2): this should be fixed in QGIS master (QGIS 3). Just tested, works
> fine
> ad 3): yes, would be useful
> I am sure there are more issues. Would be useful to collect them for
> further improvements.
> Do you want to start a document? I would be glad to assist you.
> Let's also think about rasters. E.g. saving to a Geopackage should be as
> easy as saving to a TIFF-file. Also in Processing. But I have to admit I
> haven't really tested the raster part of Geopackage a lot. Maybe some
> things are already possible.
> Greetings,
> Andreas
> On 2017-09-28 06:47, Stéphane Henriod wrote:
> Dear all
> I am making a few tests with Geopackages and I have a short list of
> behaviors or features that, IMO, would be quite nice to have in Qgis. But
> I'd like to have feedback from some of you before moving ahead. Maybe the
> majority disagrees with my opinion or maybe I have overlooked some already
> existing features :-)
> [currently testing on 2.18.11]
> 1) Creating a Geopackage DB
> As far as I see, the only way to create a Geopackage DB in Qgis is to
> create a new Geopackage layer. But there are cases where I don't want to
> create a new layer. I only want to create an empty Geopackage, so that I
> can later, e.g. import a bunch of shapefiles into it.
> Of course, I can create a geopackage layer and delete it later, but this
> is not super intuitive for the users
> 2) Qgis browser
> It would also be very handy to be able to browse the content of a
> Geopackage within the Qgis browser, so that we can drag-and-drop layers
> directly to the project
> 3) Multi-export to Geopackage
> If I want to migrate a whole project from Shapefiles and Tiff files to a
> single Geopackage DB, I would like to multi-select them and drag-and-drop
> them into an existing Geopackage DB (or  a *Save all layers as...* in the
> contextual menu, when I select more than 1 layer)
> Just curious if those needs / ideas resonate and / or if there are already
> plans in these directions
> Thanks and cheers
> Stéphane
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170928/9555e520/attachment.html>
