[Qgis-user] ubuntugis-nightly: No providers for GRASS and SAGA in Processing?
Patrick Dunford blackwhitekez at gmail.com
Thu Sep 28 01:39:08 PDT 2017
It's simply that you can eliminate the ubuntugis dependency as a later
release of Ubuntu does not require it. Running Qgis in a Vm is also a
viable option if you can't change the OS on your computer. I run Qgis
now in VMs because I can doe 100% of the things that I could do natively
and I have drawn hundreds of kilometres of production maps with the
development masters running in Virtualbox desktop VMs.
On 28/09/17 20:19, Bernd Vogelgesang wrote
> Hi Pattrick,
> sorry, but I do not understand what you are talking about.
> I'm running the nightlies of the development version and have the
> ubuntugis-unstable ppa activated.
> GRASS and SAGA are present in the ppa and are running individually
> without a problem. They are just not available through QGIS processing.
> As the nightlies are built frequently, any changes on ubuntugis should
> be adopted to within a short time. But there are still no providers
> for GRASS and SAGA.
> What does this have to do with the version of my OS? All necessary
> sources derive directly from qgis.org or ubuntugis-unstable, as far as
> I can see.
> Cheers
> Bernd
> Am 27.09.2017, 23:12 Uhr, schrieb Patrick Dunford
> <blackwhitekez at gmail.com>:
>> you can run masters up to 313ec55 (January 2017) without ubuntugis on
>> xenial, I use this one all the time as it is stable and reliable
>> while I am waiting for some bugs to be fixed in latest masters.
>> I can see your problem if you want to use the latest master though.
>> Mostly I take that option to avoid having to convert my project files
>> back to 2.18 having been doing my real life projects on 2.99 since it
>> first came out.
>> On 28/09/17 09:57, Patrick Dunford wrote:
>>> Another thread we just talked about this, it's an issue with the
>>> units not being available in ubuntugis yet
>>> Only xenial and older require ubuntugis for the latest versions, if
>>> you are running 16.10 or later, or a later debian, these issues
>>> don't occur.
>>> On 28/09/17 04:14, Bernd Vogelgesang wrote:
>>>> Hi,
>>>> just installed the development version on Ubuntu xenial from
>>>> ubuntugis-nightly repository.
>>>> In processing, there are only the qgis algos, but no grass nor
>>>> saga. In the settings, there is nothing shown about them.
>>>> Do I miss sth, or are the other providers not included yet?
>>>> Cheers
>>>> Bernd
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
