[Qgis-user] Compiling QGIS3 with grass7 from MacPorts
Patrick Dunford blackwhitekez at gmail.com
Thu Sep 28 18:14:15 PDT 2017
Ok, I'm not familirar with a separate build step, don't remember seeing
that in the install documentation, unless that is a specific variation
for your platform?
On 29/09/17 14:12, David Liontooth wrote:
> Hi Patrick,
> I'm using today's QGIS git master and get this in the configure output:
>       -- QGIS version: 2.99.0 Master (29900)
>       -- Could not find GRASS 7
> The INSTALL file makes it clear it must be built separately, but
> suggests using other "Install development frameworks".
> The installation procedure for MacOS X with MacPorts is not documented.
> Cheers,
> Dave
> On 9/28/17 5:55 PM, Patrick Dunford wrote:
>> Hi, this is only a generalised comment about building packages and
>> may not be specific enough for your application.
>> When I build packages from source they come with Grass so I don't see
>> how it would not be included in the same scripts for the platform you
>> are using.
>> Are there any error logs for building the plugins that will show what
>> is happening for example the library is not found or wrong version?
>> On 29/09/17 13:12, David Liontooth wrote:
>>> I'm interested in reading LIDAR data, which appears to require GRASS
>>> (I'm new to this).
>>> I'm trying to compile QGIS2.99 (master) on OS X and short of GRASS
>>> everything is working -- the program starts up with
>>>     open QGIS
>>> MacPorts has gdal-grass @2.2.0 (gis), which pulls in grass7. It ends
>>> up here:
>>>     /opt/local/share/grass-7.2.2/lib
>>> so for instance /opt/local/share/grass-7.2.2/lib/libgrass_lidar.dylib.
>>> How do I tell the QGIS build scripts to include grass7?
>>> Cheers,
>>> Dave
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
